  3. Update the contents in Viewfile
  • Replies 8
  • Views 19582
nidon
nidon over 14 years ago
Dear Sir.
I want to write a code to show some information.For example,if I write a code:
i= 0
while(i<10
printf("the number is %n.\n" i)
i++)
and I load it in CIW,then it will show the information in CIW window.But if I want to show these massages in a view widonw ,how could I do?
I just tied to use view command ,but it showed 10 view windows(I just want to showed a view windows,and the window can update the contents by the massage.
Thanks for you reply.
Thank you!
    win=hiCreateWindow(nil "text" "Show File")
    hiDisplayWindow(win)
    i=0
    while(i<10
      hiTextDisplayString(
        win
        sprintf(nil "The number is %n\n" i)
        nil
      i++
  • nidon
    Thanks for your reply ,Andrew.
    In fact, I'm writing a script,and I want to show the process log in the viewfile.
    And I tried your example above, I found I can not check the content if the text is too large in the viewfile when the script executing,and I have to check the content after the script finished .So, is there any solution for it?
    Thanks for your reply again!
     Regards!
    Nidon
    Nidon,
    I don't understand what your problem is - you'll have to be clearer or give an example.
  • nidon
    Oh,I sorry I can't descript the problem clearly.
    For example,I write a code to stream out gds(gds1~gds100),and hope to show the information in viewfile.
    And I tried the way you gave,when I executed the scripte.
    The viewfile will display:
    Export the GDS1----------done.(line1)
    Export the GDS2----------done.(line2)
    Export the GDS30-------done.(line30)
    Export the GDS1000-----done.(line100)
    And when the script executing,I just see the contents from line1 to line30,if I want to see more contents(line31~line100),I have to wait the script finished.
    The code as follow:
    procedure(abWriteCellGDS(libName cellName viewName streamOutKeys suffix)
        let((template fileName ipcId)
            streamOutKeys->libName=libName
            streamOutKeys->primaryCell=cellName
            streamOutKeys->viewName=viewName
            streamOutKeys->outFile=strcat(cellName suffix)
            streamOutKeys->errFile=strcat("PIPO_" cellName ".LOG")
                  gds_info
                  sprintf(nil "Writing GDS for %s/%s/%s to %s\n"  libName cellName viewName   streamOutKeys->outFile)
                  nil )
            fileName=makeTempFileName("/tmp/writeCellGDS")
            template=outfile(fileName)
            fprintf(template "streamOutKeys='%L\n" streamOutKeys)
            close(template)
            ipcId=ipcBeginProcess(strcat("pipo strmout " fileName))
            ipcWait(ipcId)
            deleteFile(fileName)
        ) ; let
    ) ; procedure
    gds_info=hiCreateWindow(nil "text" "Show File")
    hiDisplayWindow(gds_info)
             foreach(cell ddGetObj(libName)~>cells
                when(ddGetObj(libName cell~>name viewName "master.tag")
                    abWriteCellGDS(libName cell~>name viewName streamOutKeys suffix)
                ) ; when
            ) ; foreach
    Two things you want here:
                  gds_info
                  nil
                  ; additional arg t ensures that it scrolls to bottom
                  t)
            ; ensure window gets repainted if damaged (e.g. obscured)
            hiFlush()
    It will work with just the additional t in the hiTextDisplayString(), but it's better with the hiFlush() too as that means that if the log window gets obscured and then uncovered again, it repairs the contents.
  • nidon
    Thank you Andrew,it what I wanted
    Thanka a lot~
  • rish87
    rish87 over 7 years ago in reply to Andrew Beckett
    I have write a script to run pvs and used system command to run. I have directed pvs log into the file netlist_log_file.
    This is my command to run pvs.
    system( strcat("ipvs -nograph -any_flow -svs -preset " file_name " >& ./netlist_log_file"))
    Now I need a gui to view this log file. I have tried creating text window, read each line from the log file and print it on the gui.
    There are 2 drawbacks in  that method:
    1.The textdisplay will executes only after system command completes.( I need to view the log file when the pvs runs)
    2.The log file is large(aruond 7K lines) so reading each line and printing it will take time.
    Once this completes I need to run the pvs for different cell and the same gui should continue to display as the netlist_log_file gets over written.
    Can you help me on this?
    Harish
    Andrew Beckett over 7 years ago in reply to rish87
    Hi Harish,
    The easiest would be to use view("./netlist_log_file" nil nil t)
    This will auto-update as the file changes.
