  3. Customising menus in Analog Environment - menus not loa...
  • Views 780
Customising menus in Analog Environment - menus not loading
MikePJ
MikePJ over 13 years ago
I'm trying to add a custom menu to Analog Environment - I'm following the guidance in Solution 11286092 but the menu file doesn't seem to be being loaded by the system. I know that there's a certain amount of customisation to our local setup, so is there a straightforward way that I can trace what's going on and work out why the spectre.menus file isn't being loaded from ~/menus?
 I'm running ICFB 5.10.41_USR5.90.69 and our simulator is SmartSpice.
 Mike
    Mike,
    Why would you expect it to load the spectre.menus file if you're using SmartSpice rather than spectre as your simulator?
    I would expect the menus file to be called something different for SmartSpice (I don't know what, since that's a tool from Silvaco, not Cadence).
  • MikePJ
     Andrew,
     Okay... that would make sense. I'm new to this...
    [EDIT] turns out it's SmartSpice.menus - and our long-departed Cadence system admin has also moved the files to a non-standard location. The joys...
