  3. issue with member function
  • Views 14792
Rojalin
Rojalin over 13 years ago
hi,
I have a list as following:
temp=(2.12 2.04 1.96 1.88 1.8
    1.72 1.64 1.56 1.48 1.4
    1.32 1.24 1.16 1.08 1.0
    0.92 0.84 0.76 0.68 0.6
    0.52 0.44 0.36 0.28 0.2
    0.12 0.04
I want to check any arbitrary number returned by one function is there in the list or not.
I found out member function.
 m=yCoord(centerBox(obj)).This is the function which gives the value 0.12 .i want to check whether this number is there in the list or not.
So when i am giving l=member(m temp) it is giving output as nil although it is present in the list.
So how to resolve this issue?
thanks
    You almost certainly have a rounding error - maybe in the yCoord(centerBox()) function. Comparing floating point numbers with an == check (which is what member() does) is always dangerous (in any programming language). You could use:
    tempInt=foreach(mapcar num round(num*1000))
    member(round(m*1000) tempInt)
  • Rojalin
    thanks andrew.
    what does this num refer to?
  • Rojalin
    hi,
    Thanks.i got this done.
