  3. Browse button not working in Skill GUI
  • Views 15309
Sandeep4386
Sandeep4386 over 14 years ago
I'm having issue with Browse button in GUI. It does nothing when I click it. Below is my code:
 ;creation of form
Browse=hiCreateButton( ?name 'browse ?buttonText "Browse" ?callback "SyncBrowser()")
hiCreateAppForm(
?name 'skillGUI
?formTitle "A simple GUI"
?fields
list( list(Library 0:40 600:30 200)
list(Cell 0:70 600:30 200)
list(Cellview 0:100 600:30 200)
list(Run 50:160 100:30 200)
list(ViewOutputFile 200:160 200:30 200)
list(Browse 450:160 100:30 200)
            );list
);hi createAppForm
 procedure(SyncBrowser()
ddsSyncWithForm(
skillGUI()
'Library
'Cell
'Cellview
'Browse
);ddsSyncWithForm
 );Procedure
Any clue where I am going wrong?
Sandeep
    Sandeep,
    Assuming that the rest of the code is this:
    Library=hiCreateStringField(?name 'Library ?prompt "Library")
    Cell=hiCreateStringField(?name 'Cell ?prompt "Cell")
    Cellview=hiCreateStringField(?name 'Cellview ?prompt "View")
    Run=hiCreateButton(?name 'Run ?buttonText "Run")
    ViewOutputFile=hiCreateButton(?name 'ViewOutputFile ?buttonText "View")
    then quite understandably I get an error when I hit the Browse button:
    *Error* eval: undefined function - skillGUI
    That's because the first argument to ddsSyncWithForm() is incorrect. It should be skillGUI not skillGUI() . Also the second argument should be 'browse and you should not have 'Browse at the end (see the documentation).
     ddsSyncWithForm(
        skillGUI
        'browse
        'Library
        'Cell
        'Cellview
    );ddsSyncWithForm
  • Sandeep4386
    Andrew,
    That worked perfectly. Thanks.
