  3. Error about dbCreateParamInstByMasterName
  • Views 15892
nidon
nidon over 14 years ago
Dear sir:
 I want to invoking a pcell in layout,and I write a code as follow:
     if(null(ddGetObj("Libname")) then libId=dbCreateLib("Libname") techSetTechLibName(libId "PDK_lib"))
     cellId=dbOpenCellViewByType("Libname" "test" "layout" "maskLayout" "w")
     dbCreateParamInstByMasterName(cellId "PDK_lib" "rppoly" "layout" get_pname(concat("list" "_" 1)) 0:0 "R0" 1
                list(
                     list("segW" "float" 10u)
                     list("segL" "float" 10u)
     rodAlign(
              ?alignObj           rodGetObj(get_pname(concat("list" "_" 1)))
              ?alignHandle        'lowerLeft
              ?refPoint           list(0.0 0.0)
But there are some warnnings: the cellview ID is not a voliad datebase ID.Can you help me?
 Thank you very much!
    This is probably because you didn't pass the cellView ID as the second argument to rodGetObj. Pass cellId as the second arg.
    BTW, I wouldn't use get_pname and concat to build a string like this - you end up creating a symbol in the symbol table unnecessarily. OK if it's a one off, but in general I'd do: sprintf(nil "list_%d" 1) or sprintf(nil "%s_%d" "list" 1) assuming that the "list" and 1 might be coming from variables in your real code (I'm guessing here).
  • nidon
    Thanks Andrew
    And I have another question,I find
    if I use pcDefinePcell(
    list(
    rodAlign(
    even I don't define the cellId to rodGetObj,the code execute seems right.
    I can not understand,is any difference there?
    Try reading the documentation for rodGetObj() (search in cdnshelp for "rodGetObj"). It explains precisely why there's a difference inside pcDefinePCell.
    Actually even the quick help in cdsFinder explains this - type help(rodGetObj) in the CIW to see this too.
  • nidon
    Thans again~
