  3. How to following cursor of action in virtuoso
  • Replies 8
  • Subscribers 150
  • Views 22741
bojue00
bojue00 over 14 years ago
hi all
  i have a problem !
 How to following cursor of action in virtuoso ?
 how to get the X and Y coordinate of the cursor and dX(dY) on the status bar.
    Tank
  • psill
    psill over 14 years ago
    Not sure how you are going to use it, so here are some functions that may help you.
     hiGetPoint(getCurrentWindow())
    For edit in place:
     geWindowToEditPoint( hiGetCurrentWindow() enterPoint())
    Getting the delta of cursor may be in the cellWindow variables
    getCurrentWindow()~>?? ( there a lot of variable to sort through > 150 variable I think)
    or you may try
    leGetRefPoint(geGetWindowCellView())
    to you current position.
    Sorry I could be more help with the delta x/y but I have not much need to find those values since Cadence does a good job on displaying that information.
    I did some limited testing on the functions, but I don't know how you are going to be using the function in your script.
    Paul
  • bojue00
    Paul
     thanks for your reply.
    I know these function.  I want to get to when the cursor moves auto print cursor( not pointer ) of coordinate.  Just like dX(dY) or X(Y) display on the status bar  in virtuoso.  I don't know what function may do it.
    Example:  1. Enter point (reference point)  in the draw path mode ( leHiCreatePath() ) .
                    2. Move cursor to anywhere.
                    3. Auto get current cursor of coordinate in the place.
                    4. Calculate between the last point entered(reference point) and cursor distance.
    So step 3 is important.  But almost function all need click the mouse to get point.'
    procedure( NextPathStartPoint()
     cvw = getCurrentWindow()
     GetCursorPoint = hiGetPoint(cvw)
     xStartNextPoint = xCoord( drStartNextPoint )
     yStartNextPoint = yCoord( drStartNextPoint )
     dxCoord = xCoord( GetCursorPoint ) - xStartNextPoint
     dyCoord = yCoord( GetCursorPoint ) - yStartNextPoint
     if(( dxCoord < GetCurrentPathWidth ) then
      NextPathDirectionMark = "up-down"
     else
      if(( dyCoord < GetCurrentPathWidth  ) then
       NextPathDirectionMark = "left-right"
      else
       println( list( "dx:" dxCoord ))
       println( list( "dy:" dyCoord ))
      );end if
     );end if
     when(( PathDirection == "Horizontal" )
      when(( NextPathDirectionMark == "up-down" )
       ;up-down direction
       if(( dyCoord > 0 ) then
        ;up
        yNewNextCoord = yStartNextPoint - GetCurrentPathWidth/2
        NewStartPoint = list( xStartNextPoint yNewNextCoord )
       else
          if(( dyCoord < 0 ) then
         ;down
           yNewNextCoord = yStartNextPoint + GetCurrentPathWidth/2
          else
         NewStartPoint = drStartNextPoint
          );end if
       );end if
      );end when
      when(( NextPathDirectionMark == "left-right" )
       if(( dxCoord > 0 ) then
        ;right
        xNewNextCoord = x2RefPoint - xConOffsetCoord
        NewStartPoint = list( xNewNextCoord yStartNextPoint )
       else
          if(( dxCoord < 0 ) then
         ;left
         xNewNextCoord = x2RefPoint + xConOffsetCoord
          else
          );end if
       );end if
      );end when
      println( list( "Horizontal: " NewStartPoint ))
     );end when
     when(( PathDirection == "Vertical" )
        yNewNextCoord = y2RefPoint - yConOffsetCoord
       else
         yNewNextCoord = y2RefPoint + yConOffsetCoord
          else
          );end if
       );end if
      );end when
        xNewNextCoord = xStartNextPoint - GetCurrentPathWidth/2
       else
         xNewNextCoord = xStartNextPoint + GetCurrentPathWidth/2
          else
          );end if
       );end if
      );end when
      println( list( "Vertical: " NewStartPoint))
     );end when
     when(( NewStartPoint != nil )
      deletePoint()
      enterPoint( ?points NewStartPoint )
     );end when
    );end procedure
            Tank
  • psill
    Did try Dynamic Display?
    From the cellview window Options->Dynamic Display... and Click on the  Show Info button. Draw a path, rectangle, or hover a shape and info about the what you are doing or the shape will be displayed.
     It has some nice features. I wish Cadence would add a skill function to print out to the info balloon.
  • dmay
    dmay over 14 years ago
    You can. Take a look at the odcReg* commands.
    You can define a custom SKILL extension to specify your own information to be displayed in the Info Balloon box. The information you specify appears below a dashed line in the info balloon box.
    The SKILL extension must be defined at the object level. Global levels (VLS, Objects, and Shapes) are not supported. Also, the application must be specified for each SKILL function.
    For example,
    odcRegShapeRect("Layout-XL" "test custom SKILL function")
    To turn the display of the SKILL extension on, click the Custom SKILL Function button on the Setup tab of the Dynamic Display form for the object specified in the SKILL function.
    Here is an example that will print a custom via's override parameters to the info balloon in L and XL:
    procedure(myv(obj @optional (x nil)) sprintf(nil "%L" obj~>viaHeader~>overrideParams))
    odcRegVia("Layout" "myv")
    odcRegVia("Layout-XL" "myv")
    Derek
  • bojue00
    i'm tried it.
    but callback info: error eval undefined function - odcRegVia
    i not finding odcReg* command. whether have more detail documents and usage method.
    tank
  • skillUser
    skillUser over 14 years ago
    Hi Tank,
    Which version are you using?  Your last post would suggest that you are using IC5141 rather than an IC61x version.
    Lawrence.
  • dmay
    You must be using an older version of Cadence. Are you running 5.1.41? 6.1.5? I was responding to psill's comment about Dynamic Display.
    Derek
  • bojue00
    i'm using IC5141.
    tank
