  3. somethings about panic file
  • Replies 7
  • Views 22091
nidon
nidon over 14 years ago
Dear sir:
 I write a code to generate layout(about more than 80000 layouts),but when I run it,sometimes the CIW window will show the information:
CellView(test1 layout) from lib(test) is saved in the panic file(/path/test/test1/layout/layout.cd-)
To recover do:
dbOpenPanicCellView("test" "test1" "layout")
And then,the icfb will closed by itself,and I have to rerun the code again.
I guess the reason is I generated too more layouts one time,isn't it?
If it is,how shoud I do
Thank you!
  • Quek
    Quek over 14 years ago
    Hi nidon
    This means that your Virtuoso session has crashed. It might be due to your codes or it might be a bug. Please report the issue to your local Cadence support together with the CDS.log file that shows the crash stack.
    Best regards
    Quek
  • nidon
    Hi quote:
    Thanks for your reply.As what you said, I check the CDS.log file and the Virtuoso did crashed.
    But I found other two problems:
    1.The reason cased crashed is seems I generate too much layouts ont time and it will make Virtuoso crashed.And I reduce the number of layouts,the code executed well.
    2.I found that,at the beginning of the code executed,the code running very fast,but after a few time,the speed is begin to slow.So,is there any way to keep the speed?
  • Quek
    Hi nidon
    It is good to know that you have a workaround for the crash. Perhaps you might want to examine your codes to make it more efficient (e.g. use dbClose to purge unused cellviews, etc) so that it does not take up more memory as it runs. You can use the "Profiler" in "ciw:Tools->SKILL Development" to check the amount of time/memory used up by various functions in your codes. It requires a SKILL development license.
    Best regards
    Quek
  • marcelpreda
    marcelpreda over 14 years ago
    Regarding #1 reason could be the memory - to much memory used and no posibility to alloc more.
    I guess that if this is the case there you soubd see some message in CDS.log, before the message which referes to panic file.
    Regarding #2, have a look on function  hiSetUndoLimit(n_undoLimit)
     Before starting to create the layouts call hiSetUndoLimit(0).
    This will disable the Undo edit feature, but the procedures like creating/resizing/deleting shapes should run faster.
    I found it very useful when doing thousands operations with shapes.
    Best Regards,
    Marcel
  • nidon
    Thanks for Quek and  marcelpreda
    I check my code,and I found I use dbOpenCellViewByType and don't use the dbClose to release the memory generated by dbOpenCellViewByType .
    So,I think it's the key reason.
    And for your suggestions to  improve the speed of script,I did a test for them.
    I use the command groups dbOpenCellViewByType(fileA) ,dbOpenCellViewByType + dbClose(fileB),dbOpenCellViewByType +dbClose+hiSetUndoLimit(0)(fileC) in three files(each file total generate 60000 layouts) .And run them at one time.
    And the result is running time of fileB > fileA  >= fileC.
    I feel very insteresting here,theoretically speaking I use dbClose to release the memory,so the time of file A should be the longest time in the three.But the result is the longest file is fileB(I run these files in three computer).
  • marcelpreda
    I think that is OK to have exec_time(fileB) > exec_time(fileA).
    The idea is that dbClose() is also saving data on disk, and this opperation is time consuming .
    Best Regards,
    Marcel
  • nidon
    Thanks for your advice,marcelperda.
    It makes the file average executing time is reduced more than 30%.
    Thanks for your kindly support,marcelperda and Quek.
