  3. Align column of a output text file
  • Views 16729
Aritra
Aritra over 14 years ago
Is there any way to align the column of a output text file?
For example, I want to store the instance name & location to a file.
p=outfile("~/inst.txt")
foreach(a geGetEditCellView()~>instances
fprintf(p strcat("\n\t" a~>cellName "\t\t" artMakeString(a~>bBox)))
 close(p)
Now the cell name will varry in length, so the tab will also varry. As a result the bBox location will not be aligned to a column. Is there any way print cell name aligned to a column & bBox location to next column ?
I am using IC5.
  • marcelpreda
    marcelpreda over 14 years ago
    Hi there,
    The idea is to find the longest cellName (as string) and to use it in fprintf.
    The code bellow should work
    ;; find the length of longest cellName
    max_strlen =0
        if( max_strlen < strlen(a~>cellName) then
            max_strlen = strlen(a~>cellName)
        fprintf(p strcat( sprintf(nil "\n\t%%-%ds" max_strlen) "\t%s") a~>cellName artMakeString(a~>bBox))
    close(p)
    Best Regards,
    Marcel
  • dmay
    dmay over 14 years ago
    In case you are new to programming, Marcel's answer may seem a little confusing. Essentially, you want to use the features of the format string for fprintf. Here is the simple solution to your question:
    fprintf(p "%-25s %s\n" a~>cellName artMakeString(a~>bBox))
    This says, print a 25 character string that is left justified (%25s would be right justified), followed by a string without a length specification. If any of your cell names happen to be longer than 25, then your columns won't line up in that case because the full string will still be printed rather than truncated. Marcel's solution determines the maximum string length and then dynamically creates the format string (the %-25s) to use the maximum string width. If a hard coded column width is good enough, then the line above should be sufficient.
    Derek
