  3. Selecting All Signals of a Bus in GUI mode
  • Views 16165
swdesigner
swdesigner over 14 years ago
Here's what I'm trying to accomplish. Any help will be super :
I want to plot all signals from a bus. The easiest way to accomplish this is to (1) go to ADE > Results > Direct Plot > Transient Signal
Now, you (2) click on the bus and a new dialog pops up asking you to select bits, you can (3) click Select All and then (4) click Ok. Then, you can (5) go to the Schematic and hit ESC and all signals will be plotted (AWV). I have a bindkey to do (1). But, I still have to do (3), (4) and (5).
How can I define a procedure that effectively does :
sevDirectPlot(session 'asiiPlotTranSignalCB)  ; (1)
; let user select the bus (2)
_astiSelectAllIteratedCB ; (3)
; (4) and (5)
Any help would be super.
Thanks!
  • swdesigner
    swdesigner over 13 years ago
                    ;  Bind key for ResultsàDirect PlotàTransient signals
    hiSetBindKey("Schematics" "<Key>F10" "sevDirectPlot(sevSession(getCurrentWindow()) 'asiiPlotTranSignalCB)")
                   ;Function for plotting buses
    procedure(plotbus()
                   ;  Call the esc function earlier ,this is done because after we ok the form this function does not work
                    ; So we call it earlier
    hiRegTimer("astiCancelSelect(hiGetCurrentWindow())" 10)
                   ; Set context to the UI which shows bus signals
    hiiSetCurrentForm('astiSelectItemForm)
                   ;Select all members of the bus
    _astiSelectAllIteratedCB()
                   ; Ok the form after selection
    hiFormDone(astiSelectItemForm)
                   ;Function ends here
    ; Bind key to call the plot function
    hiSetBindKey("Schematics" "<Key>F11" "plotbus()")
    1.       Run simulation .
    2.       After simulation is complete, click on the schematic window and press F10
    3.       This will enable the cursor and select the desired bus to be plotted.
    4.       Once you select the bus it will bring the UI for selecting the bits to be plotted.
    5.       Just select the schematic window and press F11 key. This will plot all the bits of the bus.
