  3. create schematic from layout using skill.
  • Subscribers 150
  • Views 16922
151515
151515 over 14 years ago
I want to create schematic from layout using skill.
i know SKill coding.
I dont know how to start-with and where to start with.
Can someone help me on this?
Thanks & Regards,
  • 151515
    I copied pmos and nmos from other schematic using these commands.
    pmos = car(setof(i inst i~>cellName == "PCH_1P0V" ))
    nmos = car(setof(i inst i~>cellName == "NCH_1P0V" ))
    schCopy(pmos cv list(0:0 "R0"))
    schCopy(nmos cv list(0:0.01 "R0"))
    but the copied pmos and nmos does'nt have all the properties as that of original one such as width,length and drain/source/gate are not defined in the copied one.
    How to copy the pmos with the properties retained?
    And how to connect a wire using skill say from drain of pmos to drain of nmos?
    Sumone please help me with this issue..
    Thanks & Regards,
  • BruceD
    BruceD over 14 years ago
    what you are trying to do is very complex i think using skill - especially if you have a lot of components.  Did you think abouthow you are going to manage flatten pcells? with your approach, it will be very tough using skill.
    anyway, one idea could be:
    If you have a layout, and if you use a verification tool, why don't you create a netlist from the layout directly (possible with Calibre, i don't know with Assura)
    Once you have the spice netlist with all the parameters and the connections, just do a cdl in or a spice in in virtuoso.
    Then you have a schematic =)
    good luck.
    bruce
  • dmay
    dmay over 14 years ago
    You can use dbCopyProp:
    dbCopyProp(
    g_object1
    g_object2
    => t / nil
    Copies all the properties of one database object to another database object.
    Derek
