  3. How to create marker in viva using skill or ocean xl?
  • Subscribers 150
  • Views 17011
Reinice
Reinice over 14 years ago
I want to create a marker in viva using skill/ocean xl.
My target is to mark points in a plot that fails the required specs(min,typ,max).
Also I want to create a table which is the counter part of the plot and tells if a point/s pass or fail
Example:
Time          Voltage          Remarks
10u           900u                FAIL
10.1u        1                     FAIL
10.2u        1.16                PASS
How can I do this in skill or ocean xl?
BTW, I 'am using version 6.1.5
Thanks and Regards,
Reinice
    You can't really do this currently. There is however support for spec markers in ADE XL - so maybe that does what you want? I'm not sure there's an OCEAN API to create them though - you should contact customer support if you want to do this so an enhancement CCR can be filed.
  • Gareth Higgins
    Gareth Higgins over 10 years ago
    Hello Andrew,
    Is this still the case that markers are not able to be created through SKILL?
    Gareth
    Gareth,
    You can create markers using awvPlaceXMarker() or awvPlaceYMarker(), and these have been available for many years (even in IC5141, if my memory is correct), but the specific marker that was being requested in the original post wasn't (and still isn't) possible. There is also now a special kind of marker called a "Bookmark" which can be created with awvPlaceBookmark() which might be handy (this was added in later IC616 ISRs)
