  3. SKILL code to generate lower routes with same path properties...
  • Replies 24
  • Views 28386
SKILL code to generate lower routes with same path properties of the selected path
Neeraj Vardhan
Neeraj Vardhan over 14 years ago
I am trying to generate lower routes with same path properties as of the selected path. Can any one assist me how can i do it using SKILL.
  • Neeraj Vardhan
    rodCreatePath(
                                   ?cvId cv
                                   ?layer MBL
                                   ?width w
                                   ?pts pnts
                                   ?choppable nil
                                   ?beginExt 0
                                   ?endExt 0
                                   ?encSubPath list(
                                                list(
                                                       ?layer list("M2" "drawing")
                                                       ?beginOffset 0.0
                                                       ?endOffset 0.0
                                                       ?enclosure 0.0
                                                       ?choppable t
            ?subRect   cond(
      (w <= 0.20
       list(
           list(
                                                         ?layer   list("VIA1" "drawing")
                      ?width     0.05
                  ?length     0.05
                                                         ?beginOffset  -0.05
                                                         ?endOffset    -0.05
                                                         ?beginSegOffset 0
                                                         ?endSegOffset 0
        ;?space 0
                                                         ?sep 0
                                                         ?choppable t
                                                         ?justification "center"
        ?gap "distribute"
            (w >= 0.21 && w <=0.33
       list(
                                         list(
                      ?width     0.05
                    ?length     0.05
                      ?beginOffset  -0.05
                                  ?endOffset    -0.05
          ?beginSegOffset 0
                                                         ?endSegOffset 0
                                                         ?space via1_spc
                                                         ?sep 0.065
                                                         ?choppable t
                                                         ?gap "distribute"
                      list(
                      ?width     0.05
                    ?length     0.05
                              ?beginOffset  -0.05
                                                         ?endOffset    -0.05
          ?beginSegOffset 0
          ?endSegOffset 0
          ?space via1_spc
          ?sep -0.065
          ?choppable t
          ?gap "distribute"
            (w >= 0.34
       for(i 1 via_cont
       list(
                                         list(
                      ?width     0.05
                    ?length     0.05
                      ?beginOffset  -0.05
                                  ?endOffset    -0.05
          ?beginSegOffset 0
                                                         ?endSegOffset 0
                                                         ?sep 0.0
                                                         ?choppable t
                                                         ?gap "distribute"
    list(
                      ?width     0.05
                    ?length     0.05
                      ?beginOffset  -0.05
                                  ?endOffset    -0.05
          ?beginSegOffset 0
                                                         ?endSegOffset 0
                                                         ?space via1_spc
                                                         ?sep -(((via1_w/2)+via1_spc)*(i+1))
                                                         ?choppable t
                                                         ?gap "distribute"
                      list(
                      ?width     0.05
                    ?length     0.05
                              ?beginOffset  -0.05
                                                         ?endOffset    -0.05
          ?beginSegOffset 0
          ?endSegOffset 0
          ?space via1_spc
          ?sep (((via1_w/2)+via1_spc)*(i+1))
          ?choppable t
          ?gap "distribute"
         );for
        );rodCreatePath_end
           cv=geDeleteSelSet()
    );end
    hiSetBindKey("Layout" "Ctrl<key>8" "metalStackUp()")
    i have tried to insert an for loop inside the cond statement, i got an error " mapcar: argument #2 should be a list (type template = "ul") - t"  can't we assign for loop inside an cond statement?
    Hi Neeraj,
    The trouble is that the for() function always returns t, whereas you want something that returns an appended list of the contents from each time you call it.
    What I suggest you do is something like this:
    ; first build a list of numbers
    listOfNums=nil
    for(i 1 via_cont listOfNums=tconc(listOfNums i))
    listOfNums=car(listOfNums)
    ; then transform the list of numbers into a concatenated list of
    ; subrect lists
    foreach(mapcan i listOfNums
      list(
        list(
          ?layer ...
        list(
          ?layer ...
    The idea is that the body of the foreach(mapcan ..) returns a list of your three subrect definitions, and these will be concatenated - so if via_cont was 3, you'd end up with a list of 9 subrect definitions. If the foreach(mapcan ...) is the last thing in the branch of the cond(), it will be the return value to the ?subRect
    There's several ways of skinning this cat, but the above is relatively straightforward.
  • Neeraj Vardhan
    Hi andrew,
    Thankyou very much. the code is working fine.
    I am facing problem in determining the object type of selected instance/path/rect etc..
    a=geGetSelSet()
     x=a~>objType
    if(x == "path" then
    printf("this is a path") else printf("this is not a path"))
    the above program when executed is not recognizing the objType and always prints the second statement.
    Thanks & Regards
    Neeraj Vardhan
    Neeraj,
    That would be because geGetSelSet() returns a list of the selected objects, and so your variable a will be a list. Because of that, x will also be a list of object types - so it will be ("path") rather than "path". Commonly people write code that only deals with a single selected object, in which case if your first line was a=car(geGetSelSet()) it would work. Or instead you could do:
    foreach(a geGetSelSet()
      x=a~>objType
    and then it would do the statements in the body of the foreach for each selected object.
