  3. Get current command option
  • Subscribers 150
  • Views 18310
psill
psill over 14 years ago
Is there a better way of getting the current command option than from the command option gui?
Is there a celliew/window variable that has the current option and the other command options?
Example of part of the script:
 case( hiGetCurrentCmd(hiGetCurrentWindow())
              ("Stretch"
                        unless(boundp('leStretchForm) hiDisplayForm(leStretchForm))
                        if(hiIsFormDisplayed(leStretchForm) hiiToggleEnterForm(leStretchForm))
                        theForm         = leStretchForm
                        currOpt         = theForm~>keepWiresConnected~>value
                        optList         = theForm~>keepWiresConnected~>items
                        unless(dirBool optList = reverse(optList))
                        optAssoc        = buildOptList(optList)
                        nOpt            = cadr(assoc(currOpt optAssoc))
                        theForm~>keepWiresConnected~>value = nOpt
                        printf("Set option %s\n" nOpt)
                        hiChangeBannerLabel(win sprintf(nil "%s\n" nOpt) 0)
    I don't really know what you mean by the "current option and the other command options". What are you actually trying to do?
  • psill
     In the command Stretch, when you bring up the command option,  hiToggleEnterForm(), for the type of stretch you want the tool to perform; All wires and vias,  Spine wires only,  No wires and vias.
    Is there an environment variable that has the command options list. I did not see a variable that has the information of the command option from  hiGetCurrentWindow()~>? or geGetWindowCellView()~>?
    It is not big a deal to get the information from the command option gui, but I thought it would be better code to get the information from an environment variable.
    psill
    There's no such thing as a general list of options for each command. Each command will have encoded necessary options onto the options form, but how that has been done is specific to each command.
  • bonnieatcds
    bonnieatcds over 11 years ago
    Hi Andrew, Is there a way to save all settings on the "stretch option" form? User do not want to re-set the settings every time launch Cadence. Thanks, Bonnie
  • skillUser
    skillUser over 11 years ago
    Hi Bonnie,
    there are settings in the .cdsenv for Chain Mode, Via Mode and Keep Wires Connected:
    layout viaMode cyclic "Single"
    layout chainMode cyclic "selected"
    layout keepWiresConnected cyclic "spine"
    layout keepGuardRingEndsConnected boolean nil
    And so on - is this what you are looking for?  If so you can look through the following file to try to find any others that you are interested in:
    `cds_root virtuoso`/tools/dfII/etc/tools/layout/.cdsenv
    Hopefully this will help you.
    Lawrence.
  • bonnieatcds
    Thanks, it solved my problem!
