  3. How to create markers using SKILL?
  • Views 17577
Reinice
Reinice over 14 years ago
SignalMarkerHi All,
How Can I create markers for Analog and Digital Signals using SKILL?
Example:
1. RiseTime (X , Y) of a squre waveform, RiseTime (X , Y) pointing to posedge of a square waveform.
2. FallTime (X , Y) of a squre waveform, FallTime (X , Y) pointing to negedge of a square waveform.
3. SettlingTime (X , Y) of a Band Gap Output, SettlingTime (X , Y) pointing to time where output voltage settles.
Thanks and Regards,
Reinice
  • Reinice
    Hi All,
    Please See Link Below to view images about my earlier post.
    https://docs.google.com/drawings/d/188zmaPhR9t14JVN5A5x9x4HWMQHaMM2hDRkMj9B48xI/edit
    https://docs.google.com/drawings/d/1KNs_o-QMJT-eWlliVx5Z49F5dq3xXzP316RCkUj5e5U/edit
    Please use google chrome to view image.
    Thanks and Regards,
    Reinice
    AnalogWaveformMarker
    Reinice,
    There's no SKILL API to add such markers currently. You can add horizontal and vertical markers using awvPlaceYMarker and awvPlaceXMarker, but there's no API to support adding point or delta markers. Enhancement CCR 317631 is requesting this - I suggest you log a service request and a duplicate can be filed to register your interest.
    There is an upcoming feature planned to support interactively adding risetime/falltime type markers on the graph (I did some internal testing recently - the precise release date is not defined yet) - but again, there's no SKILL API for it yet.
    With all the work on ViVA that has happened for IC615, the first concern was to provide a good interactive tool with sensible use models; the SKILL API will catch up later.
    Kind Regards,
  • Reinice
    Thanks for the info.
    Thanks and Regards,
    Reinice
