  3. What is the setup in .cdsplotinit to create waveform window...
  • Replies 7
  • Views 19095
What is the setup in .cdsplotinit to create waveform window to *.png?
Reinice
Reinice over 14 years ago
Hi All,
I used
hardCopyOptions(?hcOutputFile "myGraph.png")
hardCopy()
to create waveform window to *.png but I' am having an error telling that I need a .cdsplotinit. I don't know how to setup .cdsplotinit for this and I don't know where to find .cdsplotinit.
Can anyone please help. Thanks in advance.
Thanks and Regards,
Reinice
    Reinice,
    Unfortunately it's a historical thing - there's a CCR to address the need for a .cdsplotinit (it shouldn't be needed in this case because you're not using it).
    It's covered in the plotting documentation, but the simplest thing is to create a ~/.cdsplotinit with the following contents:
     Encapsulated PostScript|Encapsulated PostScript: \
            :manufacturer=Adobe: \
            :type=epsf: \
            :resolution#300: \
            :maximumPages#1: \
            :paperSize="5x5 inches" 1500 1500: \
            :paperSize="8x8 inches" 2400 2400: \
            :paperSize="Unlimited" 72000 72000:
    This is primarily intended for printing from schematics and layout - this entry just defines a "printer" for outputting EPS.
  • Reinice
    Can you site me some example on how to setup .cdsplotinit to save waveform window to a *.png?
    Actually my target is to save the window waveform in *.png or *.jpg file just like doing File>save image in ViVA. But in my case I want to do this in SKILL.
    Thanks and Regards,
    Reinice
     Reinice,
    You do not need to put anything specific in the .cdsplotinit to save to png or jpg. You just have to have a .cdsplotinit existing - as I said, this is a rather odd need, but it's because the OCEAN interface to producing an image is performed via the printing API - even though it doesn't actually using the printing capability within ViVA at all.
    We are considering separating the API to save images from the hardCopy() function - the problem is that we're overloading both printing and saving of images into a single API, which over-complicates things. This is a historical decision, but with the increased flexibility we have in IC615 for saving images, it is making less sense now.
    So, if you use the .cdsplotinit I provided above - or indeed any .cdsplotinit - you will be able to save images in any format using the SKILL API.
  • Reinice
    It's working now! Thanks a lot. But I notice that it only saves the active subwindow and not all subwindow in a current window. Is there function to save all subwindow? Also is there a setup to make it's background to white? To minimize the use of disk space.
    Thanks and Regards,
    Reinice
    Reinice,
    You might find this solution useful.
  • Reinice
    Reinice over 13 years ago
    I' am having some problem in accessing the link.
    Thanks and Regards,
    Reinice
    Reinice,
    Do you have a support.cadence.com account? If so, the link should work. If you're from a customer on maintenance, you can get one using your  license server hostid - otherwise if with a University, I believe that Europractice provides a mechanism for getting readonly accounts (no service request creation), and for other parts of the world I believe you can also have a support login (via whoever is responsible for the Cadence tools at your university).
