  3. Auto search for cellmap file
  • Subscribers 148
  • Views 16071
kb how
kb how over 13 years ago
Knowing that for layer mapping and object mapping during stream-in and stream-out, virtuoso will auto search for techLibName.objectmap and techLibName.layermap under technology library.
Is this apply to cellmapping as well? I did a several try but its not working. If it doesn't, may i know is there any way i can set default for xstream to auto seach for techLibName.cellmap?
  • kb how
    Hi All,
     I found a solution by using template file.
    I created a template file and input the default cellmap file with other default setting. Then, i setenv for
        setenv XST_OUT string "template_file"
  • kb how
    I can even use command to set the cellmap file
    xstSetField("cellMap" cellMapFile)
