  3. How to get coordinates of layers
  • Subscribers 153
  • Views 23291
PDCHino
PDCHino over 14 years ago
Greetings!
I want to get coordinates of layers of the selected object.
What what SKILL commands or program will I use?
For example:
I have a resistor in a layout, I select it then execute a SKILL commands or program.
The result will be the x and y coordinates of the layers of the resistor I selected.
  • psill
    psill over 14 years ago
    I am assuming you the layout is flat data or shapes, not instances or pcells
    This might get you some info to start.
    load the script
    Select your shapes then excute the script.
     procedure(printPts()
    let(    (type
        (cnt 0)
        (objList geGetSelSet()))
    foreach(obj objList
        ++cnt
        type = obj~>objType
        case(type
            ("inst"
                printf("%s %L at %L\n" type obj~>xy))
            ("rect"
                printf("%s on layer %L at %L\n" type obj~>lpp obj~>bBox))
            ("polygon"
                printf("%s on layer %L at %L\n" type obj~>lpp obj~>points))
            ("path"
            ("pathSeg"
                printf("%s on layer %L at %L\n" type obj~>lpp list(obj~>beginPt obj~>endPt)))
            ("label"
                printf("%s on layer %L at %L\n" type obj~>lpp obj~>xy))
            (t    printf("%s not defined\n" type))
    printf("%n objects selected\n" cnt)
    ); end of let
    ); end of printPts
    You can find more about the objects from selecting an object/s then executing in the ciw the command geGetSelSet()~>? this will output the variables to the object or geGetSelSet()~>?? will output the variables and values.
    psill
  • PDCHino
    Thanks psill!
     It works.
  • Binoy CK
    Binoy CK over 12 years ago
    Hi ,
    I want to get the code for finding the coordinates of a Layer which is inside a Pcell ?
    And it is not flattened .
    Binoy
    Hi Binoy,
    If you have the instance id of the instance, you can access all the shapes by doing:
    instId~>master~>shapes
    or on each layer purpose pair by doing:
    M1=car(exists(lpp instId~>master~>lpps lpp~>layerName=="Metal1" && lpp~>purpose=="drawing"))
    M1~>shapes
    of course, having got the shapes, you can find out the ~>bBox of each or whatever you want. The "coordinates of a layer" is a bit vague, so it's not obvious what you want to do with them.
    You might need to use dbTransformPoint or dbTransformBBox of points or bounding box with instId~>transform as the second argument if you want the coordinates referred to the cellView the pcell is instantiated in, otherwise they are relative to the origin of the pcell.
  • AshokDeEmperor
    AshokDeEmperor over 7 years ago in reply to Andrew Beckett
    Hi, I used this method to extract layers from pcell. how ever would you please let me know. how do I trace the connectivity at current hierarchy of those shapes. The pcells are present at current hierarchy/cellview. using above I extracted "PO" layers and filtered to find out only those "PO" shapes where net name is defined. however these net names are names inside PCELL like "G" for gate. at current hierarchy these "PO" shapes have "GT" connectivity. so how to get this "GT" connectivity from the extracted shapes. please let me know if I need to provide any further info>
    below is my code
    my_po_shapes = car(exists(a inst_id~>master~>lpps a~>layerName == "PO"))
    shapes_with_connectivity = setof(a my_po_shapes~>shapes a~>net~>name!=nil)
    thanks And Regards,
    Ashok Kumar Mishra
    Andrew Beckett over 7 years ago in reply to AshokDeEmperor
    If you look at the instTerms on the pcell instance, you can find the instTerm with a name "G" and then find the net for the instTerm. From that net, you can look at all the ~>figs on that net, and that will give you all the shapes on the net at this level connected to the G terminal of the device in question. From these shapes you can filter all of those which are on the desired layer-purpose.
