  3. Instance Properties
  • Subscribers 150
  • Views 17155
Instance Properties
CadenceUsr
CadenceUsr over 13 years ago
Hi All,
I'm customizing the sheet symbol from the standard Cadence library US_8ths and I would like to know more about the properties database layout of a Cadence instance. Up till now, the following properties are known:
cellView~>lastSchematicExtraction
cellView~>libName
cellView~>cellName
cellView~>viewName
Are there other properties?
Another question concerning the sheet symbol in the US_8ths is what does it mean the @rev and @author properties? I tried to look for the documentation about this but unsucceeded to find. Could you help? Thanks in advance/
  • marcelpreda
    marcelpreda over 13 years ago
     Hi there,
    To get a list of all cellview memeber just use
    cellView->?
    you will get a list with all the properties .
     If you want also the values of the respective properties use:
    cellView->??
    You will get a list like (prop1 val1 prop2 val2 ... propN valN)
    Some values could be also lists or dbObjects , it meants that you may want to dig down.
    Also on any object/inst in nsch or layout you can do like this:
    select the object
    run:
    x = css()
    ;; see all memebers
    x->??
    ;; list properties
     x->prop~>name
     ;; list props values
    x->prop~>value
    BR,
    Marcel
  • CadenceUsr
    Hi Marcel,
    Your tips are very helpful. I can get the required instance properties. Thanks for your help.
