  3. Utility to convert Path to Path Seg
  • Subscribers 148
  • Views 15462
Paramjeet
Paramjeet over 13 years ago
I have a tool which only works on Path Segs.
Is there any skill code which can convert all the PATHS to PATHSEG.
I have created the signal using path command, whereas the tool which I have to work on requires the signal to be created using create wire command. Is it possible to change all the PATH
Thanks & Regards
Paramjeet Singh
    This solution was written by a colleague to do what you want.
  • Paramjeet
     Thanks a lot Andrew for your help.
    It was really a helpful code.
