  3. How to know if leRegUserObjectSelectionFilter is running...
  • Views 16138
How to know if leRegUserObjectSelectionFilter is running?
psill
psill over 13 years ago
Is there a way to determine if  leRegUserObjectSelectionFilter running?
When I use leUnregUserObjectSelectionFilter() and leRegUserObjectSelectionFilter is running I get an output t and when it is not running it outputs t also.
Is there a function to determine the state of  leRegUserObjectSelectionFilter?
psill
    What do you mean by "is running"? I don't quite understand the question...
  • psill
    How do I detect if the session has invoked leRegUserObjectSelectionFilter, so if it is executed I could leUnregUserObjectSelectionFilter to turn off the select filter. And if it is not filtering, to reinvoke leRegUserObjectSelectionFilter.
    psill
  • dmay
    dmay over 13 years ago
    I don't know how to check to see if the ObjectSelectionFilter currently has a function registered. However, it seems like you should be able to setup your own means of managing this. Rather than registering and unregistering the filter, just register it once at the beginning of your session. Then, within the procedure that you register, you can check the status of a global variable or form to determine whether or not you do any filtering. It is up to your command to return t or nil. If you wish not to filter, then you always return t.
    For example, in the code we register, we always return t if the cellview is read-only. This allows a user to select whatever they want in read-only mode, but we can enforce our filter criteria when the cellview is in edit mode.
    Derek
     I also use this code to support registering more than one filter:
    /* abLeMultiSelectionFilter.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 02, 2008
    Modified
    By
    A mechanism to allow multiple filters to be registered
    for leRegUserLayerSelectionFilter and leRegUserObjectSelectionFilter
    Defines:
    abLeRegUserLayerSelectionFilter(t_funcName)
    abLeUnregUserLayerSelectionFilter(t_funcName)
    abLeRegUserObjectSelectionFilter(t_funcName)
    abLeUnregUserObjectSelectionFilter(t_funcName)
    These are similar to the original functions with prefix le instead of
    abLe, but note that the original unreg functions don't need a function
    name (this does, because it needs to know which function is
    being unregistered)
    SCCS Info: @(#) abLeMultiSelectionFilter.ils 12/02/08.11:51:17 1.1
    (let ()
      *    (defineFilterWrapper regFunc unregFunc filterName "uut")     *
      *   Closure which returns a list of three functions - one to be   *
      *   the registration function, one the unregistration function,   *
      *  and one the filter itself. Needs to know the function objects  *
      *   to perform the single registration, unregistration, and the   *
      *              ultimate (global) name of the filter.              *
      *  The idea is that this keeps track of multiple registrations,   *
      *  and then calls all the registered filter functions sequence,   *
      * so turns with a single registered filter function, can actually *
      *                 call several functions instead.                 *
      (defun defineFilterWrapper (regFunc unregFunc filterName "uut")
        (let (filterList registered)
          ; local function to register the selection filter
          (defun register (func)
            (when (stringp func) (setq func (stringToSymbol func)))
            (unless (member func (car filterList))
              (setq filterList (tconc filterList func)))
            (unless registered
              (setq registered t)
              (regFunc filterName)
            t
          ; local function to unregister the selection filter
          (defun unregister (func)
            (setq filterList
                  (lconc nil (remove func (car filterList))))
            (unless (car filterList)
              (setq registered nil)
              (unregFunc)
            t
          ; local function to actually be the selection filter
          (defun filter (obj)
            (forall func (car filterList)
                    (funcall func obj))
          (list register unregister filter)
      ; Use the closure to define the multi-version of
      ; leRegUserLayerSelectionFilter and leUnregUserSelectionFilter
      (let (funcs)
        (setq funcs (defineFilterWrapper leRegUserLayerSelectionFilter
                                         leUnregUserLayerSelectionFilter
                                         "abMultiLayerSelectionFilter"))
        (setq abLeRegUserLayerSelectionFilter (car funcs))
        (setq abLeUnregUserLayerSelectionFilter (cadr funcs))
        (setq abMultiLayerSelectionFilter (caddr funcs))
      ; leRegUserObjectSelectionFilter and leUnregUserObjectSelectionFilter
      (let (funcs)
        (setq funcs (defineFilterWrapper leRegUserObjectSelectionFilter
                                         "abMultiObjectSelectionFilter"))
        (setq abLeRegUserObjectSelectionFilter (car funcs))
        (setq abLeUnregUserObjectSelectionFilter (cadr funcs))
        (setq abMultiObjectSelectionFilter (caddr funcs))
      t
     And here's an example that can (optionally) use this - and uses the type of approach that Derek suggests (registers it once, but then uses a flag to control whether it is active or not). In this case the flag is a lexically scoped (rather than global) variable, but the principle is what matters here. Also, the actual functionality in the code is not relevant if using IC615 because it's now a standard feature of the layout editor (Edit->Protect) - so I include it here for illustration purposes.
    /* abProtect.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Nov 14, 2008
    Modified   Nov 19, 2008
    By         A.D.Beckett
    Package for implementing a protection mechanism for
    layout. The idea is that you can protect objects, and
    consequently they are then not selectable.
    For example:
    ; initialize the system
    abProtect->init()
    ; protect the selected objects
    abProtect->protectSelected()
    ; turn off protection mode so everything is
    ; selectable (t to turn back on)
    abProtect->setOption('protectMode nil)
    ; select all the protected things
    abProtect->selectProtected()
    ; unprotect all the selected objects (have
    ; to turn off protect mode first, or use selectProtected)
    abProtect->unprotectSelected()
    ; unprotect everything
    abProtect->unprotectAll()
    ; protect everything in a named group
    abProtect->protectGroup("groupName")
    abProtect->unprotectGroup("groupName")
    ; hilight the protected objects
    abProtect->hilight()
    ; and unhilight them
    abProtect->unhilight()
    ; using abSelectObjByName code, prompt user to pick
    ; a figGroup to be protected
    abSelectObjByName('figGroups geGetEditCellView() abProtect->protectObj)
    ; and to unprotect
    abSelectObjByName('figGroups geGetEditCellView() abProtect->unprotectObj)
    ; using an alternative select filter registration
    ; function - e.g. from abLeMultiSelectionFilter.ils
    ; must be done before init. This allows additional filters to be
    ; defined
    abProtect->setOption('regSelectionFilter 'abLeRegUserObjectSelectionFilter)
    abProtect->init()
    SCCS Info: @(#) abProtect.ils 12/02/08.13:05:00 1.4
    (importSkillVar abProtect)
    (setq abProtect
          (let (
                (options (makeTable 'options nil))
                (optionNames '(protectMode
                                deselectAfterProtect hilightLPP
                                hilightHalo
                                haloPosition haloType haloThickness
                                haloTransparency haloDrawStroke
                                regSelectionFilter))
            *                (setOption option value "sg")                 *
            *   Exported function for setting an option for the protect    *
            *    package. Needs the name of the option and a value. The    *
            *     name is checked to ensure it is a valid option name.     *
            (defun setOption (option value "sg")
              (if (memq option optionNames)
                (setarray options option
                          (if (listp value) (copy value) value)
                (error "Unrecognised option %L - must be one of %L\n"
                       option optionNames)
              ) ; defun setOption
            *                 (getOption @optional option)                 *
            *  Exported function for getting the value of an option or a   *
            *               list of the legal option names.                *
            (defun getOption (@optional option)
              (if option
                  (arrayref options option)
                         option optionNames)
                (sort (copy optionNames) 'alphalessp)
              ) ; defun getOption
            *                   (protectSelected [wid])                    *
            *    Exported function for protecting the selected figures     *
            *            in the specified (or current) window.             *
            (defun protectSelected (@optional (wid (hiGetCurrentWindow)))
              (setSGq (geGetSelSet wid) t protected)
              ; Deselect if the preference has been set
              (when (arrayref options 'deselectAfterProtect)
                (geDeselectAll wid)
              t
              ) ; defun protectSelected
            *                  (protectGroup name [wid])                   *
            *    Exported function to protect a group (figGroup) given     *
            *                          the name.                           *
            (defun protectGroup (name @optional (wid (hiGetCurrentWindow)))
              (let (theFigGroup)
                (setq theFigGroup
                      (dbGetFigGroupByName (geGetEditCellView wid) name))
                (when theFigGroup
                  (putpropq theFigGroup t protected)
                ) ; let
              ) ; defun protectGroup
            *                 (unprotectGroup name [wid])                  *
            *              Unprotect a group, given its name               *
            (defun unprotectGroup (name @optional (wid (hiGetCurrentWindow)))
              (let (theFigGroup)
                (setq theFigGroup
                (when theFigGroup
                  (dbDeletePropByName theFigGroup "protected")
                ) ; let
              ) ; defun unprotectGroup
            *                     (protectObj d_obj)                       *
            *                 Given an object, protect it.                 *
            (defun protectObj (obj "d")
              (putpropq obj t protected)
            *                     (unprotectObj d_obj)                     *
            *                Given an object, unprotect it.                *
            (defun unprotectObj (obj "d")
              (dbDeletePropByName obj "protected")
            *                  (unprotectSelected [wid])                   *
            *   Exported function to unprotect the selected objects. Of    *
            *   course, you need to select them first, so probably need    *
            * to either turn off the protectMode, or select the protected  *
            *                items using selectProtected()                 *
            (defun unprotectSelected (@optional (wid (hiGetCurrentWindow)))
              (foreach fig (geGetSelSet wid)
                       (dbDeletePropByName fig "protected")
              t) ; defun unprotectSelected
            *                (operateOnAllObjects cv func)                 *
            *    Internal function to apply a specified function to all    *
            *   objects. This avoids having to replicated this iteration   *
            *                      in lots of places.                      *
            (defun operateOnAllObjects (cv func)
              (foreach objs
                       (list
                         (getSGq cv shapes)
                         (getSGq cv instances)
                         (getSGq cv vias)
                         (getSGq cv figGroups)
                         (getSGq cv mosaics)
                         (getSGq cv blockages)
                         (getSGq cv rows)
                         (getSGq cv markers)
                         (getSGq cv areaBoundaries)
                         (getSGq cv guides)
                         (getSGq cv routes)
                         (getSGq cv steiners)
                         (list (getq cv prBoundary))
                         (list (getq cv snapBoundary))
                       (foreach fig objs
                                (func fig)
              ) ; defun operateOnAllObjects
            *                   (selectProtected [wid])                    *
            *    External function to select all the protected objects     *
            (defun selectProtected (@optional (wid (hiGetCurrentWindow)))
              (let (cv (protectMode (arrayref options 'protectMode)))
                (setq cv (geGetEditCellView wid))
                ; Temporarily suspend the protect mode
                (setarray options 'protectMode nil)
                                     (lambda (fig)
                                       (when (getq fig protected)
                                         (geSelectFig fig)
                ; And then turn it back on (if on previously)
                (setarray options 'protectMode protectMode)
              ) ; defun selectProtected
            *                     (unprotectAll [wid])                     *
            *          External function to unprotect everything           *
            (defun unprotectAll (@optional (wid (hiGetCurrentWindow)))
                (errset
                                       (lambda (fig)
              ) ; defun unprotectAll
            *                      (unhilight [wid])                       *
            *     External function to unhilight the protected objects     *
            (defun unhilight (@optional (wid (hiGetCurrentWindow)))
              (let (hs)
                (setq hs (getq wid protectHilightSet))
                (when (geIsValidHilightSet hs) (geDeleteHilightSet hs))
                t
            *                       (hilight [wid])                        *
            *   External function to hilight (with Halos if desired) the   *
            *                      protected objects                       *
            (defun hilight (@optional (wid (hiGetCurrentWindow)))
              (let (hs cv)
                (unhilight)
                (setq hs (geCreateHilightSet cv (arrayref options 'hilightLPP)))
                                     (lambda (fig)
                                         (geAddHilightRectangle hs
        (getq fig bBox))
                (when (and
                        (isCallable 'geSetHilightSetHaloParameters)
                        (arrayref options 'hilightHalo)
                  (geSetHilightSetHaloParameters
                    hs
                    (arrayref options 'haloPosition)
                    (arrayref options 'haloType)
                    (arrayref options 'haloThickness)
                    (arrayref options 'haloTransparency)
                    (arrayref options 'haloDrawStroke)
                (putpropq hs t enable)
                (putpropq wid hs protectHilightSet)
                t
              ) ; defun hilight
            *                      (selectFilter fig)                      *
            *    Function, exported as abProtectSelectFilter, which is     *
            * registered as the selection filter function. This is called  *
            *    for each object to determine whether it is selectable.    *
            (defun selectFilter (fig)
              (cond
                ((null (arrayref options 'protectMode)) t)
                ((getq fig protected) nil)
                (t t)
              ) ; defun selectFilter
            *                            (init)                            *
            *     Exported function to initialize the protect system.      *
            (defun init ()
              (funcall
                (arrayref options 'regSelectionFilter)
                "abProtectSelectFilter")
              ) ; defun init
            ; Export the select filter
            (setq abProtectSelectFilter selectFilter)
            ; Defaults
            (setarray options 'protectMode t)
            (setarray options 'hilightLPP '("y0" "drawing"))
            (setarray options 'hilightHalo t)
            (setarray options 'haloPosition "over")
            (setarray options 'haloType "plain")
            (setarray options 'haloThickness "normal")
            (setarray options 'haloTransparency 50)
            (setarray options 'haloDrawStroke t)
            (setarray options 'regSelectionFilter 'leRegUserObjectSelectionFilter)
            ; The DPL containing all the exported functions for the
            ; package
            (list nil
              'setOption setOption
              'getOption getOption
              'protectSelected protectSelected
              'unprotectSelected unprotectSelected
              'selectProtected selectProtected
              'unprotectAll unprotectAll
              'protectGroup protectGroup
              'unprotectGroup unprotectGroup
              'protectObj protectObj
              'unprotectObj unprotectObj
              'hilight hilight
              'unhilight unhilight
              'init init
              ) ; list
            ) ; let
          ) ; setq abProtect
