  3. Select objects in specific layer that intersect with objects...
  • Subscribers 150
  • Views 16759
Select objects in specific layer that intersect with objects in another layer
Peter K
Peter K over 13 years ago
 I would like to select all objects in LAYER1 which are touching objects in LAYER2.  Any ideas on how to do this with SKILL?
 Thanks!
Peter
  • Slayer
    Slayer over 13 years ago
    IMHO, the simplest action - in the loop take need command (for example dbLayerAnd and etc.) and look at the result if result shape add initial shape to the specific list and result add to the delete list.
    For example:
    procedure(Test(pcCV "d")
       let( (l1_list l2_list toDelete needeedShapes tmpShape
            l1_list = setof(i pcCV->shapes i->layerNAme == LAYER1);
            l2_list = setof(i pcCV->shapes i->layerNAme == LAYER2);
            foreach(l1 l1_list
               foreach(l2  l2_list
                  tmpShape = dbLayerAndNot(pcCV LAYER1 l1 l2);
                  when
                    needeedShapes = cons(l1 needeedShapes);
                    toDelete = cons(tmpShape toDelete);
      foreach(s toDelete dbDeleteObkect(s));
       neededShapes
