  3. schCreateWire route method creates flight instead of fu...
  • Views 17082
schCreateWire route method creates flight instead of full
Reinice
Reinice over 13 years ago
Hi All,
I' am using schCreateWire to wire my Circuit Under Test(ex. bandgap) and it's stimulus(ex. vpulse, vpwl, gnd) automatically. Here is the context of my schCreateWire:
schCreateWire(cvId "route" "full" list(xvalf:yvalf xvalnf:yvalnf) 0.0625 0.0625 0.0)
My question is that why does this function having this context creates some "flight"(dashed type) as route method instead of "full"(solid type)? Meaning not all wires are created in solid type.
Is this a limitation of schCreateWire?
Best Regards,
Reinice
     Hi Reinice,
    This typically happens when things are too congested - you see the same behaviour when you are routing manually in the schematic editor (it's the same router underneath).
    The flight lines are still connected, but there's just not space (or the router isn't smart enough to find a route, at least not without taking a long way around) to fulfill the route.
  • Reinice
    I see. My design is too congested, I have lots of terminal pins in my Circuit Under Test and most of it are connected to it's assigned stimulus. Is this going to affect the analysis during spectre simulation? and creating netlist in ADE?
    Thanks and Regards,
    Reinice
     Hi Reinice,
    No, it shouldn't affect anything - the connectivity is still correct.
