  3. [permutation] how can I make all Instance combinations?
  • Views 15866
pacowon
pacowon over 13 years ago
Hi, I have a question with my skill language.
I wanna make permutation list with plural cell Instances.
For example , If I have a,b,c instances
 I wanna return list(a b c) list(a c b) list(b a c) list(b c a) list(c a b) list(c b a) => 3*2*1 lists!!
 I tried all day with
procedure(permutaion(()
prog(()
 Inst = list(a b c d)
foreach(***********)
)) but may be I'm not smart enogh to deal with this skill .....
somebody help  me out...
    Hopefully this code will help you:
    /* abPermutations.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Mar 28, 2012
    Modified
    By
    Generate permutations in lexical order
    Almost certainly there's a fancier way to do this...
    A few versions of doing this. One based on a perl algorithm (uses arrays),
    and the second two are more LISPy ways of doing this
    Some of these functions require SKILL++ lexical scoping so please
    ensure file keeps the ".ils" suffix *************************************************** SCCS Info: @(#) abPermutations.ils 03/28/12.09:50:21 1.1 */
    (defun abPermutations (listOfObjects) (let (arrayOfObjects size indexArray) ;-------------------------------------------------------------------- ; Convert everything to arrays to allow faster manipulation ;-------------------------------------------------------------------- (setq arrayOfObjects (listToVector listOfObjects)) (setq size (sub1 (length arrayOfObjects))) (setq indexArray (makeVector (add1 size))) (for i 0 size (setarray indexArray i i)) ;-------------------------------------------------------------------- ; Local function to swap two array entries ;-------------------------------------------------------------------- (defun swap (a b) (let (tmp) (setq tmp (arrayref indexArray a)) (setarray indexArray a (arrayref indexArray b)) (setarray indexArray b tmp) ) ) ;-------------------------------------------------------------------- ; Local function that can be called recursively to generate permutations ;-------------------------------------------------------------------- (defun genPerm () (let ((k (sub1 size)) (j size) retVal) (setq retVal (foreach mapcar ind (vectorToList indexArray) (arrayref arrayOfObjects ind))) (while (and (geqp k 0) (greaterp (arrayref indexArray k) (arrayref indexArray (add1 k)))) (postdecrement k)) (if (minusp k) (list retVal) (progn (while (greaterp (arrayref indexArray k) (arrayref indexArray j)) (postdecrement j)) (swap j (postincrement k)) (setq j size) (while (greaterp j k) (swap (postdecrement j) (postincrement k)) ) (cons retVal (genPerm)) ) ) ) ) (genPerm) ) ) (defun abPerms (l) ;---------------------------------------------------------------------- ; Local function to remove only the first match in a list ; which means that it copes with repeated values in the list ;---------------------------------------------------------------------- (defun removeFirst (val l) (let (found) (setof elem l (cond (found t) ((equal val elem) (setq found t) nil) (t t) )))) (if (null l) '(nil) (mapcan (lambda (x) (mapcar (lambda (y) (cons x y)) (abPerms (removeFirst x l )))) l))) (defun abPermsUniqueList (l) (if (null l) '(nil) (mapcan (lambda (x) (mapcar (lambda (y) (cons x y)) (abPermsUniqueList (remove x l )))) l)))
  • pacowon
    Wow!!! Thanks!!
    This is exactily what I wanted!!
    I just noticed that there's a typo in the comments of the file - it should really have a ".ils" suffix because some of the functions use SKILL++ lexical scoping - so my advice is that if you use this, please ensure that it has a .ils suffix.
    I'll edit the post with the code to make this clearer.
