  3. sort lists in SKILL/OCEAN
  • Subscribers 150
  • Views 9559
mbchang
mbchang over 13 years ago
 I have a list which includes several lists inside. Is there any way that I can sort the lists alphabetly based on the first part of each list (signal name)?
Thanks!
list(
list("V105A_ymax_v9overshoot_1"   float(0.9975)  float(1.1025) "[V]"   )
list("V105A_riseTime_v9ramptime_1"   float(300u)  float(2m) "[s]"   )
list("V5A_DS3_delay10_v5a_on_1"   float(0.0)  float(500u) "[s]"   )
list("V33A_DSW_peakToPeak_v4vripple_1"   float(0.0)  float(50.0m) "[V]"   )
list("V5A_DS3_ymin_v2pgoodincr_1"   float(4.65)  float(4.85) "[V]"   )
list("DPWROK_delay90_pwrok_delay_1"   float(10m)  float(15m) "[s]"   )
list("V33A_DSW_average_v4voutavg_1"   float(3.135)  float(3.465) "[V]"   )
list("V105A_ymin_v9pgoodincr_1"   float(0.965)  float(1.03) "[V]"   )
    The simplest way to do this is to use sortcar() with your example. Assuming myList contains the list:
    myList=sortcar(myList 'alphalessp)
    That outputs this:
     (("DPWROK_delay90_pwrok_delay_1" 0.01 0.015 "[s]")
        ("V105A_riseTime_v9ramptime_1" 0.0003 0.002 "[s]")
        ("V105A_ymax_v9overshoot_1" 0.9975 1.1025 "[V]")
        ("V105A_ymin_v9pgoodincr_1" 0.965 1.03 "[V]")
        ("V33A_DSW_average_v4voutavg_1" 3.135 3.465 "[V]")
        ("V33A_DSW_peakToPeak_v4vripple_1" 0.0 0.05 "[V]")
        ("V5A_DS3_delay10_v5a_on_1" 0.0 0.0005 "[s]")
        ("V5A_DS3_ymin_v2pgoodincr_1" 4.65 4.85 "[V]")
    In the absence of sortcar, you could do:
    myList=sort(myList lambda((a b) alphalessp(car(a) car(b))))
    In other words, the second argument to sort is a function that compares two values and returns t if the first is "less" than the second. You can then do whatever comparison you like - here I'm using alphalessp on the car of each entry, which is your signal name here. I could equally well sort on the second entry in each list (the numbers) by doing:
    myList=sort(myList lambda((a b) cadr(a)<cadr(b)))
    And so on.
  • mbchang
     never mind. I think I can build the list twice.
    Thanks for the tips.
    Jerry
  • skillUser
    skillUser over 13 years ago
     Hi Jerry,
    To respond to your last question (that's now disappeared) - how about sorting everything in the list except for the first element?  In that case you could sort the cdr of the list, that is to say, everything in the 'tail' of the list, after taking the first item (the 'head') away.  Beware that "sort" is a destructive list operator, so you must save the return result of the sort function since it modifies the list in place.
    Hopefully this helps you?
    Lawrence
  • berndfi
    berndfi over 13 years ago
     This could probalby do it.
    Andrew wasn't the intial code from you? Can't remeber.
    /****f* /listProcessing/LPindexSort
    * NAME
    *   LPindexSort
    * SYNOPSIS
    *   LPindexSort( x_index0 l_listOfList u_comparefn )
    * DESCRIPTION
    *   This function sorts a list of lists acoording to the elements given by a
    *   index for the sublist.
    * ARGUMENTS
    *   x_index0        - Index for the sublist element which sould be used for the
    *                     sort.
    *   l_listOfList    - A list of lists.
    *   u_comparefn     - The compare function applied for the sort.
    * RETURN VALUE
    *   l_result
    * EXAMPLE
    *   l_listA = list(
    *               list( "Kiwi" "Banana" "Grape" )
    *               list( "Apple" "Grape" "Banana" )
    *               list( "Banana" "Kiwi" "Apple" )
    *               list( "Apple" "Banana" "Kiwi" )
    *   LPindexSort( 1 l_listA 'alphalessp )
    *   => (("Kiwi" "Banana" "Grape")
    *          ("Apple" "Banana" "Kiwi")
    *          ("Apple" "Grape" "Banana")
    *          ("Banana" "Kiwi" "Apple"))
    *   l_listB = list(
    *               list( 6 3.0 2 )
    *               list( 1.0 4 5 )
    *               list( 4.0 2 6 )
    *               list( 1 2 7.0 )
    *   LPindexSort( 1 l_listB 'lessp )
    *   => ((4.0 2 6)
    *          (1 2 7.0)
    *          (6 3.0 2)
    *          (1.0 4 5))
    * SOURCE
    procedure( LPindexSort( x_index0 l_listOfList u_comparefn )
        let( ( l_sortedListOfList )
        l_sortedListOfList = sort(
            l_listOfList
        lambda( ( a b )
            while( and(
                    nth( x_index0 a ) nth(  x_index0 b )
                    equal( nth( x_index0 a ) nth(  x_index0 b ) ) )
                    setq( a cdr( a ) )
                    setq( b cdr( b ) ) )
                    and( nth( x_index0 a ) nth(  x_index0 b )
                    apply( u_comparefn list( nth( x_index0 a ) nth(  x_index0 b ) ) ) )
    ) ;; close let
    ) ;; close procedure
    I agree (the code wasn't from me though - I don't believe in having the type of variables encoded in the names as it makes them hard to read, so it wasn't my code).
