  3. Help on create VIA in 6.1.4 version
  • Subscribers 150
  • Views 16675
Sarvani
Sarvani over 13 years ago
Hi all,
I am able to create contact in IC5141 version using leCreateContact command.  But this is not works in 614 version. Please let me know create a VIA in layout in 614 version.
Thank you,
Sarvani
    leHiCreateVia or dbCreateVia.
  • Sarvani
     What is d_viaDefId in dbCreateVia? I got below error for dbCreateVia command.
      x=y=0
    dbCreateVia( geGetEditCellView() "M2_M1_S" list(x y) "R0"
                                                 list( list("cutRows" 2)             ;row
                                                 list("cutColumns" 4)               ;column
                                                 list("cutSpacing" list(x y))       ; cut spacing for x and y
                                                 list("layer1Enc" list(x y))         ; enclosure for layer1
                                                 list("layer2Enc" list(x y))         ; enclosure for layer2
                                                 list("cutWidth" 0.2)                 ; cut width
                                                 list("cutHeight" 0.4)                ;cut height
                                                 list("originOffset" list(x y)))      ; j
     *Error* dbCreateVia: argument #2 should be a database object (type template = "ddltg") - "M2_M1_S"
    M2_M1_S is my via name.
    Use techFindViaDefByName() to retrieve that.
  • Sarvani
    It's working now. Thank you very much Andrew.
  • NguyenDinh
    NguyenDinh over 10 years ago
    I have a problem with this subject. My code is below:
    viaid=techFindViaDefByName(tfId "VM3_M4")
    n =6
    dbCreateVia(pcCellView viaid 0:-1 "R0"
    viaParams='(("cutRows" n)
    ("cutColumns" 1)
    ("cutSpacing" (0.1 0.1)) ; space via
    ("imp1Enc" (26.07 26.07)) ;PP
    ("imp2Enc" (0.07 0.07)) ;PDK layer
    ("layer1Enc" (0.02 0.02))
    ("layer2Enc" (0 0.03))
    It doesn't work. And Cadence give a warrning :
    *WARNING* (DB-270576): Invalid cutRows(0)
    But
    At line 4, If I use n is 6 (code is viaParams='(("cutRows" 6) ....) it's working.
    Do you have any ideal ? I want to use a parameter (n) instead a number (6) . Thank
    Yes, it's because you're passing a quoted list to the function. The quote operator means that the list is taken literally, with no evaluation. So the n in the list is passed as n not 6. Obviously it's not expecting the symbol n there, so it fails.
    Another thing - you don't really need to assign the value to a variable (the viaParams= bit) unless you're going to use it later - but maybe that was done for a good reason.
    Anyway, what you need is either:
    viaParams=list(list("cutRows" n)
    '("cutColumns" 1)
    '("cutSpacing" (0.1 0.1)) ; space via
    '("imp1Enc" (26.07 26.07)) ;PP
    '("imp2Enc" (0.07 0.07)) ;PDK layer
    '("layer1Enc" (0.02 0.02))
    '("layer2Enc" (0 0.03))
    or:
    viaParams=`(("cutRows" ,n)
    ("cutColumns" 1)
    This second form is a neat feature of SKILL - a special kind of quoted list. If you use the backquote instead of the normal single quote, then the list is taken literally except where a subexpression is preceded by a comma. Those preceded by commas get evaluated. It's actually a macro that expands into lists of lists etc, but it's a lot more succinct to type!
    If you look at viaParams after calling this, you'd see the value 6 where the ,n was. Note there's also another form that can be used inside a backquoted list - ,@ - but I'm not going to cover that here since you don't need it (this is for splicing in lists).
