  3. Subtraction Between two layers?
  • Views 15071
murtazaak
murtazaak over 13 years ago
I just started cadence couple of days back for designing my patterns, I wanted to subtract two layers and already wrote a code but not sure its a right one or not. Could anyone help me please and let me know is this a right on or not,
 load("/usr/cdscad/libw/utils/rectw.il")
procedure( subtraction( @optional origin ww tlength outlayer)
(prog (xx yy np xo yo lw)
   subl1 = nil
   subl2 = nil
   xo = xCoord(origin)
   yo = yCoord(origin)
;; Draw First rect Layer
   xx = xo
   yy = yo-ww/2.0
   r = rectw(xx yy tlength ww "metal1")
 subl1 = append(subl1, list(r))
;; Draw Second rect Layer
   xx = xo
   yy = yo-ww/2.0
   r = rectw(xx yy tlength ww "metal2")
  subl2 = append(subl2, list(r))
dbLayerAndNot((getEditRep) outlayer subl1 subl2)
  • kb how
    kb how over 13 years ago
    hi Mustazaak,
    Not sure what you're trying to do. Maybe you can give a brief description to let us understand your intension.
    Else, just use function dbLayerAndNot is help.
  • murtazaak
     Hi Melaka,
    First of all thanks for your reply, I think you are right that I didn't clearify the things in detail. I am designing the program first in Cadence. For that I am using icfb for compiling, gedit as a editor for writing my code and output of program can see in Virtuoso. Now as I mentioned the code in my previous post, actually I am creating two metal(polygon) layers on exactly same location (both layers x-axis and y-axis are same). Let suppose Layer1 and Layer2 has two layers on same location, obviously when my output come on Virtuoso I can see only one Layer but Layer1 and Layer2 should be behind it which I can't see because of same location. Now what I want is that I can subtract from Layer1 to Layer2 or vise versa so that when my output come on Vituoso it shows only Layer1 not Layer2.
    Actually I am desiging first my patterns in Cadence then I have to use E-line(lithography) on Silicon chip to write these patters. I am facing the problem that temporary my layer1 is subtract to other layer2 otherwise on E-line it write both layers that make the chip worse.
    Hope I explained in detail if not so then please ask again,
    Cheers
