  3. How to get minimum two VIA's when using AutoVIA
  • Views 803
Sarvani
Sarvani over 13 years ago
 I am using 614 version. Auto option in Create Via creates possible no. of VIA's when I click on two layers which need to be connected. If area of overlap of these two layers is very small then only one VIA is placed at that area. I would like to get minimum two VIA's at that overlap place. Please help me on this.
 Thank you,
Sarvani
    Sarvani,
    Can you move to IC615? (IC614 is no longer supported). In IC615 there's an option on the auto-via form to specify the minimum number of cuts...
