  3. problem with "XStream Out" using skill command
  • Views 1679
jazzmatazz
jazzmatazz over 13 years ago
  Hello everyone,
       I try to set some of the setings from the "Geometry" tab of the X Stream Out form using skill commands, but they don't work!?
       For example I try to set this
                xstSetField("rectToBox" "true")
           the returned value is t, but the check box is still unchecked .This happens when I try to setup and the other check boxes ( export settings) from this tab.
     Am I wrong with the commands, or there is a bug?
  Regars,
      Nikolay
  • jazzmatazz
    Hello again ,
         Everyting is fine now just after restart of the Cadence this commands works very  well
          Nikolay
