  3. create a table inside the class
  • Views 16761
skillseeker
skillseeker over 13 years ago
I would like to create a table for each instance of a class. How best to do it. If i define "makeTable" inside a defclass it gives me an error.
 defclass( pinInfo
     ( pinName   @initarg pinName )
     ( pinType   @initarg pinType )
     ( netName   @initarg netName )
     PinTable = makeTable("aTable1" 0)
     tablep(PinTable)
  );defclass
I get an error when i define it like this "*Error* slotValue: no such slot - PinTable.
    You can't just stick arbitrary code inside a class definition - you could either do it with an @initform:
    defclass(pinInfo
        (pinName @initarg pinName)
        (pinType @initarg pinType)
        (netName @initarg netName)
        (pinTable @initform makeTable("aTable1" 0))
    Then:
    > a=makeInstance('pinInfo)
    stdobj@0x8564018
    > a->pinTable
    table:aTable1
    > a->pinTable["hello"]=23
    23
    > a->pinTable->??
    ("hello" 23)
    Or you could define an initializeInstance method:
    defclass(pinInfo
        (pinTable)
    defmethod(initializeInstance @after ((obj pinInfo))
      obj->pinTable=makeTable("aTable1" 0)
    Note that the second approach only works in IC615 onwards. You could use a non-@after method, but then you'd have to make sure you call callNextMethod() appropriately to ensure that any parent objects have a chance to initialize too. The @after directive tells it to call all the other @after methods, least-specific first.The intention for initializeInstance is to handle complex initialization of objects which can't be coded via the @initform (e.g. interdependencies of the arguments).
  • skillseeker
    Thanks Andrew appreciate your help. I will use the first method suggested.
