  3. Is there a way i can cretea a function on the fly?
  • Subscribers 148
  • Views 15213
kb how
kb how over 13 years ago
May i know is there are way to create function at the fly. Meanings that create a control loop flow script to create unique function name.
Example as below (But this doesn't works)
foreach( ele list( list("funcA" funcB") list("funC" "funcD"))
    newFunctionName = stringToSymbol(strcat( car(ele) cadr(ele) ))
    (defun newFunctionName args
          (printf "Hello World - %L\n" args))
My intention is to create a function at the fly.Any idea? Is this possible?
    foreach( ele list( list("funcA" "funcB") list("funC" "funcD"))
        putd(newFunctionName lambda((args)
              printf("Hello World - %L\n" args)
    funcAfuncB("test")
    Hello World - "test"
    However, I would say that creating functions on the fly is something that is even more powerful in SKILL++ mode, because that supports the concept of "closures". For example (either type toplevel('ils) and then type this in the CIW, or put in a file with a ".ils" suffix):
    defun(CCFmakeCounter (@key (init 0) (step 1))
      lambda(() init=init+step)
    c1=CCFmakeCounter()
    c2=CCFmakeCounter(?init 4 ?step 3)
    c1() => 1
    c1() => 2
    c2() => 7
    c2() => 10
    c1() => 3
    This concept is covered in more detail in the SKILL documentation. The idea is that CCFmakeCounter() is returning a function object with the specific environment containing the arguments that were passed in (it's the same function object, but the environment changes in essence). In SKILL++ mode functions are variables, so you can much more easily pass around function objects without needing to use funcall or apply to call them.
  • kb how
    Thanks Adrew for the solution and great sharing. I should start learning SKILL++ now.
