  3. schViewToView
  • Replies 8
  • Views 14047
schViewToView
FormerMember
FormerMember over 13 years ago
Hi all,
  I want to write a skill file to update standard cell librarie all symbols  with VDD/VSS pins.
There exits all symbol view.
When I use the  "schViewToView()" function, I want to select the "Modify" function.
How could I do the job automatically?
Thanks for your great help!
Best regards,
E-Jen
    pinList=schSchemToPinList("mylib" "mycell" "schematic")
    pinList->prop->schCvCreationMethod="Modify"
    schPinListToView("mylib" "mycell" "symbol" pinList "schPinListToSymbolGen")
    Should do it.
  • FormerMember
    It works. Thanks and Happy New Year!
    Best regards,
    Lien, E-Jen
  • nosaj
    nosaj over 9 years ago
      The schPinListToView function works, however the pins added are not touching the rect of the symbol.  Is there a way to add pins to the symbol that touches the rect boundary?
    In order to do this, you'd need to change the TSG (Text to Symbol Generator) template. I did it by copying the <ICinstDir>/tools/dfII/samples/symbolGen/artist.tsg (pick whichever template you normally use on the Create->CellView from Cellview route) to a local file, myArtist.tsg. I then edited this file and changed the wireLength to 0.0 (in the symbolParams section). More details can be found in the Text to Symbol Generator appendix (Appendix C in the version I'm using) of the Virtuoso Schematic Editor L User Guide.
    Then:
    tsgTemplateMasters=cons(list("myArtist" strcat(getWorkingDir() "/myArtist.tsg")) tsgTemplateMasters)
    envSetVal("schematic" "tsgTemplateType" 'string "myArtist")
    The first adds the path to your modified template into the master list, and then the second specifies the template you want to use. This will be consumed by the schPinListToView function above, and  you'll end up with pins directly on the box of the symbol without any pin legs.
  • nosaj
    I updated symbolParam wireLength to 0.0 but it doesn't change anything.  pins are still create below the rect shape in "device" "drawing".
            symbolParam(
                origin = topLeftPin
                wireSpacing = 0.125000
                wireLength = 0.000000
                labelHeight = 0.062500
                vSideLength = 0.000000
                hSideLength = 0.000000
    I'm trying to post process these pins and legs by rotating them and moving them to the left side of the rect shape.  However, schHiRotate(t) doesn't rotate them.
    I'd like to select all lable/rect/line below ycoord = xxx, rotate  to R90, move them to the left side of the device rect :
    rect=car(setof(x cv~>shapes x~>objType=="rect" && x~>net==nil && car(x~>lpp)=="device"))
    topLeftXY=list(caar(rect~>bBox) cadadr(rect~>bBox))
    shapeList = setof(x cv~>shapes cadar(x~>bBox)<cadadr(rect~>bBox))
    ;;roate all shapeList to R90
    ;;Move them to topLeftXY
    could you guide through the last two steps.  Thanks.
  • nosaj
    should be shapeList = setof(x cv~>shapes cadar(x~>bBox)<cadar(rect~>bBox))
  • nosaj
    I figured out the last steps. Thanks.
    I think your question would have been easier to understand if you'd included a picture of what the problem was. Having re-read, you may have been talking about creating the symbol in modify mode rather than replacing the existing symbol? That's just a guess though.
