  3. Pcell symbol creation using SKILL
  • Views 18338
greatqs
greatqs over 13 years ago
I'm using SKILL code as below to generate a Pcell symbol (i.e. number of symbol terminals depend on CDF parameter).
However, every time when I load these code in CIW (i.e. IC615) into a library which attached to cdsDefaultTechLib, it will complain below warnings:
 *WARNING* (DB-270000): dbiSetCellViewDBUPerUU: The DBUPerUU attribute for viewType 'schematicSymbol' cannot be set to 1000 because it would introduce conflicts in the specified tech graph
 *WARNING* (DB-270000): dbSetCellViewUserUnitName: The UserUnits attribute for viewType 'schematicSymbol' cannot be set to 'micron' because it would introduce conflicts in the specified tech graph
The generated symbol seems to have incorrect size and scaling. Anyone knows how to workaround this?
 pcDefinePCell(
    ; target cellView
    list(ddGetObj("test") "myparsubckt" "symbol" "schematicSymbol")
    ; formal parameters
    (padNum 1)
    let((dY justify1 labelId netId
        rectId s
        xEnd xLabel2 xLoc yLoc sc
        h xShape yShape
    pcCellView~>DBUPerUU=1000.0
    pcCellView~>userUnits="micron"
    sc = 0.16
    h = padNum
    dY = (h - 1) * 0.125
    xLoc = 0.625
    ; Create outline
    dbCreateRect(pcCellView
        '("device" "drawing")
        list(0.125 * sc:-0.135 * sc
        0.5 * sc:(0.17 + dY) * sc
        '("instance" "drawing")
        list(0 * sc:-0.25 * sc
        xLoc * sc:(0.17 + dY) * sc
    ; Labels
    sprintf(s "Parasitic Network")
    dbCreateLabel(pcCellView
        '("pin" "label")
        0.3125 * sc:(0.12 + dY) * sc s "centerCenter"
        "R0" "stick"
        0.05 * sc
    labelId = dbCreateLabel(pcCellView
        '("annotate" "drawing7")
        xLoc * sc:(0.2275 + dY) * sc "cdsName()" "upperRight"
        "R0" "stick"
        0.05 * sc
    labelId~>labelType="ILLabel"
    ; Pins
    for(i 1 padNum
        yLoc = (h - i) * 0.125
        xLoc = 0
        xEnd = 0.155
        justify1 = "lowerRight"
        xLabel2 = 0.15625
        xShape = 0.15625
        yShape = ((h - i) * 0.125)
        list(xShape * sc:(yShape - 0.05) * sc
            (xShape + 0.1) * sc:(yShape + 0.05) * sc
        dbCreateLine(pcCellView
        list(xLoc * sc:yLoc * sc
            xEnd * sc:yLoc * sc
        rectId = dbCreateRect(pcCellView
            '("pin" "drawing")
            list((xLoc - 0.025) * sc:(yLoc - 0.025) * sc
            (xLoc + 0.025) * sc:(yLoc + 0.025) * sc
        sprintf(s "p%d" i)
        netId = dbCreateNet(pcCellView s)
        dbCreateTerm(netId s "inputOutput")
        dbCreatePin(netId rectId)
        sprintf(s "cdsTerm(p%d)" i)
            '("annotate" "drawing8")
            xLoc * sc:(yLoc + 0.0625) * sc s justify1
            "R0" "stick"
            0.05 * sc
    for(i 1 padNum
        xLoc = 0.625
        xEnd = 0.5
        justify1 = "centerLeft"
        xLabel2 = 0.29
        sprintf(s "b%d" i)
        '("pin" "drawing")
        xLabel2 * sc:yLoc * sc s justify1
        "R0" "stick"
        0.05 * sc
    t
    Why are you trying to set the DBUperUU and units in the cellView itself? The code:
    Seems unnecessary (based on the coordinate choices, my guess is that the defaults of 160 DBUperUU and "inches" would be appropriate). If you comment these two lines out, does it behave? I can't really see why it would cause a scaling problem if it was really ignoring these settings...
    (Note, I've not tried what you're trying because I'm nowhere near a computer to try it).
  • greatqs
    Andrew,
    Thanks for your help!
    The code is copy paste from Cadence support link as below (Solution ID:    11013814)
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY3RboIwAEW_xQ8wbRFLeSwIpZCwsDmsvDRAnStIW4xxuq8ffsDOfTy5OaABy0x71-f2pq1pL0CABkvksRgVPgzf4pJATnBZvNcJXACH1wNL-A8UgiNogpf3PERgyNJ9BHlc8JwEGw8WGNTGXqeltAci6120G-lPQkXFfeTGbo6-1SC6uV0n3H2eNqFey9zaaWTBlARK8m2qqNk9P9Jbo0xeye5gz_62nh-Kwr7Sd8boWJgvIxHKnsqhQR9dYq4XjQM9YfYgVCABh34FysxOJ-BG85sSuvoDvXFRFA!!/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
    I'm not sure why these 2 lines are needed. But if the target library has tech file of which DBUPerUU / userUnits is 1000 / "micron", the code has no issue at all and the Pcell works perfectly. Only when the target library is process independent (i.e. cdsDefaultTechLib, 160/"inch"), those 2 warnings comes up.
    I tried to comment out these 2 lines, then there is no these 2 warning as the code is executed and Pcell is generated. However the size of the Pcell is much smaller and these is impossible to route wires over terminals. I attached a screenshot to show the difference (i.e. left is to create the Pcell in a library of which BUPerUU / userUnits is 1000 / "micron" and right side is to create the Pcell in a library of which BUPerUU / userUnits is 160 / "inch")
    I don't think those lines should have any effect any more - since the DBUPerUU can't be set per-cellView any more (in OA). It's a bit odd - it works fine for me (I wrote the original solution, and the DBUperUU lines are a bit archaic and dated from IC5141, I believe).
    I suggest you contact customer support.
