  3. calculated value in ?headers of hiCreateReportField
  • Subscribers 150
  • Views 16234
The Consultant
The Consultant over 13 years ago
i creat a form with an report field. The value in the header should not a fixed value in the code, it should be a varialbe.
but i get an error, fixnum req.
here is the code
width = 30x ( some digit)
reportField = hiCreateReportField(
        ?name       'reportField
        ?title      "Report"
        ?selectMode 'multiple
        ?headers    '(
                       ("obj-type"     75   'left)
                      ("l"            75   'left)
                      ("pp"           75   'left)
                      ("description"  width   'left)
        ?choices     ch
 if i change with to e.g. 100 , everything is fine.
    If you use '(...) the list is quoted which means that nothing is evaluated inside the list. You have a couple of choices:
            ?headers    list(
                          list("obj-type"     75   'left)
                          list("l"            75   'left)
                          list("pp"           75   'left)
                          list("description"  width   'left)
    Or you could use the backquote approach which allows selective evaluation of things preceded by a comma (note the 'left will be quoted - so don't really need the quote either):
            ?headers    `(
                          ("obj-type"     75   left)
                          ("l"            75   left)
                          ("pp"           75   left)
                          ("description"  ,width   left)
    Sometimes the backquote approach is cleaner because it is clearer when you are just inserting a small number of values into an otherwise static list structure. It's actually a macro which expands into list() (and other function calls).
  • BasavarajH
    BasavarajH over 11 years ago
    Hi Andrew, I mostly have similar problem but I am trying to update a variable value into choices? but not on headers?
    I am finding your syntax (one of the above mentioned choice) matches to my syntax as below, but when I execute the code width variable box remains empty on the form.
    Should I refresh page or something, Please help me get this right?
    I have also created a post regarding this I would remove it if I find answer here. Thanks.
    ?choices    list(
                          list("obj-type"     75   )
                          list("l"            75   )
                          list("pp"           75   )
                          list("description"  width   )
    See my response to your other post (please don't make duplicate posts, or post on the end of old threads, as per the Forum Guidelines) - http://community.cadence.com/cadence_technology_forums/f/48/t/31539
