  3. how to create pin(pinname<1:10>) using skill scripting.
  • Replies 15
  • Views 14616
sritha
sritha over 13 years ago
Hi All,
I am new to skill scripting. could please give me the guidelines to create pin (pinname<1:10>).
Leela.
    Andrew Beckett over 6 years ago in reply to Purge2343 +1
    Well, you can definitely do that in SKILL. Regards, Andrew.
    Something like this. If you have a list of the names you want: names=list("adc" "a" "b" "c" "d" "e") CCFplaceInverters(names) The code will need adapting for your own inverters, but hopefully you get…
  • Purge2343
    Purge2343 over 6 years ago in reply to Andrew Beckett
    Can you help me out?I am very new to SKILL
  • Purge2343
    Purge2343 over 6 years ago in reply to Purge2343
    cv=dbOpenCellViewByType("dd" "bufd" "schematic" nil "a")
    cv1=dbOpenCellViewByType("metric" "inv" "symbol")
    schinst=dbCreateInst(cv cv1 nil list(0 0) "R0" 1)
    I used the following to get one instances, not sure how to list the name and create 71 of them
    The first question should always be "do you need to do this in SKILL"? You could just create an instance called "MYINV<70:0>" and then have an input pin "MYINP<70:0>" and output pin "MYOUT<70:0>" and then  you're done.
    Evening assuming I had the time to write this for you (which I probably don't this week as I'm on vacation for much of the week), it would need a much clearer description of precisely what you want (and why you need to do this in SKILL). How do you want the inputs to be named? How do you want the outputs to be named? Can it be a bus?
  • Purge2343
    Thank you for your reply,
    Yes, I need to do this in SKILL, I have to create a block with input output pins, each pin has a name such as
    i_adc o_adc
    There are 71 different pin names, with output pin being labelled just as o instead of i for each inverter. It shouldnt be a bus, and this is my first time on cadence SKILL and I wanted try this.
    The code will need adapting for your own inverters, but hopefully you get the idea. I use some sch functions as they are higher level and make it easier to create pins, wires etc:
    procedure(CCFplaceInverters(listOfNames @optional (cv geGetEditCellView()))
        let((master iPinMaster oPinMaster deltaY currentY Apos Ypos
    	    wireStart wireEnd wireLength inst snapSpacing)
    	deltaY=0.8
    	currentY=0.0
    	snapSpacing=0.0625
    	wireLength=0.25
    	master=dbOpenCellViewByType("sample" "inv" "symbol")
    	iPinMaster=dbOpenCellViewByType("basic" "ipin" "symbol")
    	oPinMaster=dbOpenCellViewByType("basic" "opin" "symbol")
    	; Find locations of pins on the symbol - will need to adapt
    	; if pins called something else
    	Apos=centerBox(car(car(dbFindTermByName(master "A")~>pins)~>figs)~>bBox)
    	Ypos=centerBox(car(car(dbFindTermByName(master "Y")~>pins)~>figs)~>bBox)
    	foreach(name listOfNames
    	    inst=dbCreateInst(cv master sprintf(nil "I_%s" name)
    		0:currentY "R0"
    	    currentY=currentY+deltaY
    	    ; Add input pin and wire to pin
    	    wireStart=dbTransformPoint(Apos inst~>transform)
    	    wireEnd=xCoord(wireStart)-wireLength:yCoord(wireStart)
    	    schCreateWire(cv "draw" "direct" list(wireStart wireEnd)
    		snapSpacing snapSpacing 0
    	    schCreatePin(cv iPinMaster sprintf(nil "i_%s" name)
    		"input" nil wireEnd "R0"
    	    ; Add output pin and wire to pin
    	    wireStart=dbTransformPoint(Ypos inst~>transform)
    	    wireEnd=xCoord(wireStart)+wireLength:yCoord(wireStart)
    	    schCreatePin(cv oPinMaster sprintf(nil "o_%s" name)
    		"output" nil wireEnd "R0"
    	schCheck(cv)
    	dbSave(cv)
