  3. how to create pin(pinname<1:10>) using skill scripting.
  • Replies 15
  • Views 11202
sritha
sritha over 12 years ago
Hi All,
I am new to skill scripting. could please give me the guidelines to create pin (pinname<1:10>).
Leela.
    Leela,
    Is this in a schematic, a symbol, or a layout (where probably you'd want 10 individual pins)?
    In general you'd do:
    net=dbMakeNet(cvId "pinname<1:10>")
    pinMaster=dbOpenCellViewByType("basic" "ipin" "symbol")
    pinFig=dbCreateInst(cvId pinMaster "" 0:0 "R0")
    pin=dbCreatePin(net pinFig)
    Or you could use:
    schCreatePin(cvId pinMaster "pinname<1:10>" "input" nil 0:0 "R0")
    Something like that.
  • sritha
     In layout.
    Obviously you'll need to create separate pins for each bit, so you'd do something like:
    pinWidth=0.5
    pinPitch=1.2:0
    pinOrigin=0:0
    pinLayer="Metal1"
    pinDirection="input"
    busPin="pinname<1:10>"
    foreach(pinName dbProduceMemName(busPin)
      ; create the pin shape, then the net (if it doesn't already exist), and then create the pin
      pinFig=dbCreateRect(cvId pinLayer list(pinOrigin xCoord(pinOrigin)+pinWidth:yCoord(pinOrigin)+pinWidth))
      net=dbMakeNet(cvId pinName)
      ; make sure the terminal direction is what we want too
      pin~>term~>direction=pinDirection
      pinOrigin=xCoord(pinOrigin)+xCoord(pinPitch):yCoord(pinOrigin)+yCoord(pinPitch)
  • sritha
     Thank you, I used "dbProduceMemName()" in foreach loop to get each pin bit and then created a pin.  Its working good.
  • Purge2343
    Purge2343 over 5 years ago in reply to Andrew Beckett
    *Error* eval: unbound variable - cvId
    I tried this for generating schematic pin list and I have the following error
    Andrew Beckett over 5 years ago in reply to Purge2343
    If you have the schematic window open, do:
    cvId=geGetEditCellView()
    first to store the database object of the cellView you're hoping to update into the variable cvId.
  • Purge2343
    Thank you for your reply,
    I have one more quick question.
    I want to create multiple buffers with different i/p and o/p. Is there a way to do it in skill?
    I'm sure "it" can be done in SKILL - I just don't know what it is you're asking for!
  • Purge2343
    I want to create 71 buffers with 71 input pins and 71 output pins all the buffers are of same size.
    Well, you can definitely do that in SKILL.
