  3. How do I export Spectre simulation results to a CSV file...
  • Subscribers 150
  • Views 18446
How do I export Spectre simulation results to a CSV file using the command line?
kitmonisit
kitmonisit over 13 years ago
I'm running a Spectre netlist through the Linux shell, e.g.
$ spectre my_netlist.scs
After running this simulation, I want to access the simulation results database. My questions are:
  1. What lines should I add to my Spectre netlist so that the simulation results are automatically exported to a specified CSV file?
  2. What topics in cdnshelp can help me get started with accessing the database using scripts that can be called from the command line?
    Spectre doesn't have a "CSV" output format directly. Of course, you could write a VerilogA model that monitors a node and then writes out the changes to a CSV file.
    As for writing scripts, you can either use the Spectre Measurement Description Language (in the MMSIM documentation) or OCEAN (in the IC documentation) which provide a batch way of accessing simulation results and post-processing (MDL normally runs during the simulation). There's also a Spectre Toolbox for Matlab (which is also in the documentation) which allows you to directly read simulation results into Matlab.
    Kind Regards,
  • GMSi
    GMSi over 11 years ago
    Andrew, do you have a simple example of a VerilogA model that can monitor a node to print out a CSV during a Spectre or Ultrasim simulation?
    Aaron
    Aaron,
    No, sorry. I'd offer to write one but I'm a bit pushed for time at the moment.
