  3. How to import spice netlist
  • Subscribers 150
  • Views 19295
Michael85
Michael85 over 13 years ago
I experience a weird problem when I import spice.
When I open the schematic that was created after the import process, I see that the values of Finger_width and Width are different although there is only one multiplier,
 For instance:
 Width(M) = 60u
Finger_width =400n
Number of Fngers=1
Multiplier =1
total_m=1
When I export cdl from this schematic the W value I gets is the one of the FInger_width.While The real value should be the one of the Width.
I'm using File->import->spice to import my spice file.
Can you help me to figure out how to fix this.
Michael
  • berndfi
    berndfi over 13 years ago
     This is probably the reason while one of the width values is created
    by the import and the other one is dependent on a CDF callback.
    The CDF callback is never triggered by the import.
    The one which soudl be triggerd then keeps the default value.
    So the conclusion is you need to know which is the correct width value.
    Then find out with width parameter is used for netlisting.
    And if necessary you have to trigger the CDF callback for the
    dependent value manually or with a SKILL script.
    Bernd
  • Michael85
    Hi Berndfi,
    Thanks for your replay.
    How can I trigger manually CDF callback?
    Michael
  • berndfi
    Manually you ever can trigger the callbacks over edit properties.
    You have to e.g. change and change back the initial parameter value on which
    other depend on.
    The manual approach is only useful for testing and small designs.
    But have a look at this thread and the related solution this may help.
    http://www.cadence.com/community/forums/T/17081.aspx
    https://support.cadence.com/apex/homePage
    Bernd
