  3. How do I set up Virtuoso Schematic Editor IC6.1.4 to pan...
  • Views 21302
How do I set up Virtuoso Schematic Editor IC6.1.4 to pan the view by clicking and dragging the middle mouse button?
kitmonisit
kitmonisit over 13 years ago
  • kb how
    kb how over 13 years ago
    Hi Kitmonisit,
    Are you referring to bindkeys (middle mouse) to pan the view?
  • kitmonisit
    Yes, I'm referring to bindkeys. I can't seem to find any menu item that brings up a preferences window. I think I'll have to set it up via text-based configuration file. How do I do it?
    Options->BindKeys. That said, you'd probably have to write a function to respond properly to clicking and dragging with the middle mouse key. In IC61X you can use shift or ctrl with the mouse wheel to pan left or right or up or down in response to the mouse wheel movements...
  • dmay
    dmay over 13 years ago
    How about this:
    hiSetBindKey("Schematics" "<DrawThru2>" "let((WIN mySnap) WIN=hiGetCurrentWindow() mySnap=WIN~>segSnapMode WIN~>segSnapMode=\"anyAngle\" hiVectorPan() WIN~>segSnapMode=mySnap)")
    It makes sure your segSnapMode is anyAngle and then uses hiVectorPan().
    Derek
  • kitmonisit
    kitmonisit over 12 years ago
    Where do I write that code? And how do I refer to that in the BindKeys setup window?
    I loved the fact that  you replied a year and 2 months after you were given a solution!
    Anyway, put the code that Derek showed into your .cdsinit file. If you do that, there's no need to enter it in the bindkey UI because it will have been defined from SKILL.
