  3. ADE Simulation problem
  • Views 15399
NISHAN
NISHAN over 13 years ago
We have installed new license for IC6. But the icfb version that we are using is IC5. When we open analog design environment, a warning is reported . Here we are attaching a screenshot of the warning that is coming in the icfb window. I couldn't find where to edit in .cdsenv file to go for higher tier license (ADE XL or ADE GXL which the new license supports). Here I am uploading the .cdsenv file.
Thanks in advance,
Nishanth P.V
cdsenv.doc
  • NISHAN
     Here is the screenshot of the warning window
    Not sure you should strictly need this, but try adding:
    graphic useTieredLicense boolean t
    to your .cdsenv file (e.g. in your home directory).
