  3. oa2verilog using skill
  • Views 17074
Myskill
Myskill over 13 years ago
Hi All,
              I am going to executing following code for generation of oa file to verilog file automatically present editing oa file (schematic or layout). But I am getting the error "Cannot read library libname in cds.lib because it is not open or it does not exist" could you please help on this
SKILL CODE:-
procedure(verilog()
cv = geGetWindowCellView()
libname = cv~>libName
cellnmae = cv~>cellName
viewname = cv~>viewName
s1 = ipcBeginProcess("oa2verilog -lib libname -cell cellname -view viewname -verilog viewname -recursive"
 "" nil nil nil "/remote2/test_proj/analog_project/tsmc/users/rambabu/oa2verilog1.log")
 ERROR:-
Tool:           oa2verilog          22.04.071
Running: oa2verilog -lib libname -cell cellname -view viewname -verilog viewname -recursive
Started: Mon Jan 16 15:52:35 2012 (Hostname: orange)
ERROR: (OAVLG-10009): Cannot read library libname in cds.lib because it is not open or it does not exist
Finished:       oa2verilog
Time elapsed:   0.24 seconds
CPU Time:       0.068989 seconds
System Time:    0.036994 seconds
Peak VM:        2158592 bytes
Messages:       1 error, 0 warnings
Rambabu
    Hi Rambabu,
    Variables do not get magically evaluated in literal strings, so "libname" etc are treated literally in the string passed to ipcBeginProcess.
    You'd need something like:
     s1 = ipcBeginProcess(sprintf(nil "oa2verilog -lib %s -cell %s -view %s -verilog %s -recursive" libname cellname viewname viewname)
    You'll also have to correct your code so that cellnmae is actually spelt as cellname (I decided not to repeat your typo in the code above).
    The sprintf builds the string inserting the values of the variables into the appropriate places.
  • Myskill
    Thanks for your suggestion. I am getting another error if I go as per your suggestion could you please debug and let me know
    *Error* fprintf/sprintf: format spec. incompatible with data - "Format is 'oa2verilog -lib %s -cell %s -view %s -verilog %s -recursive', argument #1 is nil"
    Rambabu
    Have you any experience with programming at all? If so, I'd expect that you'd have some understanding of basic debugging techniques - such as checking that the data you're passing to functions is valid. You might want to attend a SKILL Programming class (or any programming class), and read the SKILL Language User Guide too.
    I don't mean to be rude, but the error message fairly clearly tells you that the libname variable must be nil (i.e. not the library name). If you'd put some print statements in your code (or used the SKILL debugger) you could have checked that. The most likely explanation (assuming your code is essentially the same as that you posted earlier) is that cv is nil, because you're running with the current window not being your schematic or layout window - and hence geGetWindowCellView() is returning nil.
    That said, I'd have expected that you'd see a warning in your CIW if this was the case (and that might have alerted you to the problem?):
    *WARNING* (GE-2067): geGetWindowCellView: There is no graphical edit environment assigned to window(2) because the window is not a graphic editor window.
    Make sure that your current window is a valid graphic editor window.
    If it is a valid graph editor window, contact customer service to investigate this issue.
    Either way, check the variables in your code, and ensure they're being set properly.
  • Myskill
    thank you now it's working
