  3. add instance from library via pulldown menu.
  • Views 15526
flintae32
flintae32 over 13 years ago
Hi IC Community
My experience with Cadence’s Skill is very limited. I have created a pull down menu with sliders in the upper layout editor banner window with some success. My question is, how do I utilize the callback function to place an instance from a cell library into the layout editor window, when selected.
software version: 5.1.41
Example below:
mlf_frame = hiCreatePulldownMenu( 'editMenu "edit"
list(
hiCreateMenuItem(
                           ?name `3x3
                           ?itemText "M_3X3"
                           ?callback  "??????()"
What command should I place here in the callback function ??????. Any help would be greatly
appreciated.
Johnny
  • skillUser
    skillUser over 13 years ago
    Hi Johnny,
    This is slightly tricky - if you don't want to have to enter the lib/cell/view in a form (as initiated by a call to leHiCreateInst() ) then you would need to call something like dbCreateInstByMasterName() - the problem is that this function needs a location (origin) to place the instance at.  I would use something like "enterPoint" or "enterPoints" to gather the instance location(s) and use the addPointProc to place the instance at the most recently provided coordinate (which would be something like car(last(pts)), assuming "pts" was the argument used for the addPointProc function).  The following is an approximation of what you need:
    procedure(CCFeditMenuCB()
      enterPoints(?prompts list("Point at the location for the instance")
        ?addPointProc "CCFcreateInstAtPoint"
    procedure(CCFcreateInstAtPoint(win pts)
        geGetEditCellView(win)
        <libNameHere>   ;; this is where you hard-code the library, cell and view names
        <cellNameHere>
        <viewNameHere>
        nil             ;; let the editor choose the instance name
        car(last(pts))
        "R0"            ;; hard-code orientation of R0
    The name that you put in the edit menu item callback is "CCFeditMenuCB". Once you call this it starts a call to enterPoints that allows you to place one or more instances, and when you are doing you just hit the Escape key.
    I hope that this helps you.
    Lawrence.
  • dmay
    dmay over 13 years ago
    It's easier to just preset the create instance form:
    procedure(MYleHiCreateInst(lib cell view)
        leCreateInstForm->libName->value = lib
        leCreateInstForm->cellName->value = cell
        leCreateInstForm->viewName->value = view
        leHiCreateInst()
    Derek
