  3. How to get data of CIW in new popup window?
  • Views 15382
sritha
sritha over 13 years ago
 Is there any command to get the data from CIW(command interupter window) and display it in a new popup window.
Leela.
    Leela,
    You can use hiStartLog()/hiEndLog() to duplicate CIW log contents to another file, and then you could pop it up with the view() function. Not sure what you're trying to do - if the data is coming from a SKILL program, maybe you'd be better writing it directly to a view window or to a separate log file?
