  3. How to use hierarchy objects in dbLayerSize() command.
  • Views 16615
Sarvani
Sarvani over 13 years ago
Hi all,
        I have to generate M1 layer under M2 in layout.
cv=geGetEditCellView()
 figList2= dbGetOverlaps(cv list(car(pts) car(pts)) list("M2" "drawing") 32 t)
 dbLayerSize(cv list("M1" "drawing")   figList2 -0.08)
It works well for M2 layers in present level. Doesn't works for hirerchy M2 layers. Please help me.
Thank you,
Sarvani.
    You probably need to copy the shapes from the lower cells to the top level before sizing them. For example:
    procedure(abGetOverlapShape(overlap)
      if(listp(overlap) then
          abGetOverlapShape(cadr(overlap))
      else
          overlap
    flattenendFigList2=foreach(mapcar overlap figList2
      srcShape=abGetOverlapShape(overlap)
      dbCopyFig(srcShape cv dbGetHierPathTransform(overlap))
    Once you've sized them, you might want to delete these flattened shapes.
  • Sarvani
     Thank you very much Andrew. It's working now. I have used dbConcatTransform command for every level instead of dbGetHierPathTransform because of 5141 version.
     Sarvani.
