  3. How to save the data of fields in a Form
  • Views 17696
Neeraj Vardhan
Neeraj Vardhan over 13 years ago
Hi, i wanted to save the data of the fields in a Form to specific directory or specific folder.
    You didn't actually ask a question, so not sure what your issue is. This post gives an example of a form with an option to save and load a template to a file - maybe that addresses your need?
  • Neeraj Vardhan
    Hi andrew,
    I created a form with some fields, now i want to save the data entered into the fields into a specific folder like a log file. So that i can process the data from that log file.
    Thanks & Regards
    W.Neeraj Vardhan
    So presumably my reply (referencing the other post) answered your question?
  • StefanSL
    StefanSL over 13 years ago
    Hi W.Neeraj,
    to make it a bit easier
    (if my understanding is correct, you want to write all field/value-pairs into a file):
    you need to know the name of your form -> variable thisform
       - hiFormList() can be used to show all forms currently known -
    and you have opened a file for writing -> handle formdatafile
    now: loop over all fields of your form, get the value of each field, write name and value to your outfile;
    i've divided this into two lines, formatting a string and printing it to the outport:
    8< - - - - - - - - - - - - - - -
    foreach(thisfield thisform~>fieldList
    thisfieldvalue = get(thisform thisfield)~>value
    sprintf(printline "FIELD:%L:VALUE:%L\n" thisfield thisfieldvalue)
    fprintf(formdatafile printline)
    close(formdatafile)
    hope this helps
    Stefan
  • Neeraj Vardhan
    Thank you Andrew and Stefan for the help.
     Regards
    W.Neeraj Vardhan
  • LogicWave
    LogicWave over 10 years ago
    Test link
