  3. Help with Closures with skill++
  • Views 15196
VinceV
VinceV over 13 years ago
Need some help with closure using skill++. The below code loads fine in interactive mode but when I run it I get the error
 E- *Error* eval: not a function-1. Not sure how to debug this, any help would be appreciated. I am using this from Allegro
did not see much of any reference to Skill++ there so I thought I would post here since it is a general Skill++ question.
It seems like it is counting (see the commands below the code).
Vince
(define (makecounters)
(let ((vcount 0))
    (lambda ()
      (setq( vcount (vcount + 1) ))
      vcount)))
(define cntBy1 (makecounters))
Skill > load "test.ils"
variable makecounters redefined
t
ILS-<5>
Skill > cntBy1
ILS-<5>
E- *Error* eval: not a function - 1
Skill > cntBy1
ILS-<5>
E- *Error* eval: not a function - 2
Skill > cntBy1
ILS-<5>
E- *Error* eval: not a function - 3
Skill > cntBy1
ILS-<5>
E- *Error* eval: not a function - 4
Skill >
  • skillUser
    skillUser over 13 years ago
    Hi Vince,
    It seems you have too many parentheses for your setq statement?  Try this:
    (let ((vcount 0))
        (lambda ()
          (setq vcount (vcount + 1) )
          vcount)))
    I tested this briefly and it seems to work correctly now.
    Lawrence.
  • VinceV
    Thanks Lawrence that resolved the issue.
     Vince
