  3. Flattening a design
  • Views 18366
Flattening a design
thomas1000
thomas1000 over 13 years ago
I want to flatten a design COMPLETELY.  I am using the  leFlattenInst(...) routine to do the flattening with 31 levels and flattening the instances and mosaics so that should be enough to get them all but to be safe, but do I need to go back and somehow check to see if everything is flattened and then I somehow need make the routine recursive or does leFlattenInst(...) do that for me?
 If it needs to be recursive, how can I check to see if I am done?
    I can't see why it would not flatten everything or why you'd need to make it recursive. Of course, I'm assuming you're telling it to flatten pcells too - but assuming that, it should work. You could always check with cvId~>instances to see if there are any remaining, but I can't see why you would need to.
  • thomas1000
    Thanks, that was the answer I had hoped for.  Yes, I am telling it to flatten pcells too.  Just wanted to be sure it was covered.
  • RFStuff
    RFStuff over 13 years ago
     Dear Andrew,
    Just add to one more query to thi post:-
    Is it possible to flatten an instance/pcell and do some checking and then revert back to the original one ( non-flattened one i.e. to bring the inst/pcell to its original condition) in SKILL.
    Kind Regards,
    I probably wouldn't do this - but maybe you can do an hiUndo to undo the change?
    Why do you need to flatten it in order to do some checks? Can't you do the checks by looking at the contents of the pcell (i.e. the instId~>master)?
  • theopaone
    theopaone over 13 years ago
    Can you enlighten us with what you are trying to do? Flattening may not be the best solution for your actual problem. Especially if you have to un-flatten after your check.
     Ted
