  3. problem with starting the script in skill
  • Replies 7
  • Views 16832
imagesensor123
imagesensor123 over 13 years ago
   I have writen a script file (myCheck.sh), I would like to start the myCheck.sh in skill procedure,
  I tryed csh("myCheck.sh"), but it does not work. so what's the real process for starting the script file in skill.
my status: IC5141, spectre simulator
welcome to any suggestion!
regards,
zfeng
    That's a perfectly reasonable way of running a script. Unfortunately "it does not work" doesn't tell anyone what does not work - please be more specific. Remember that any output the script produces will appear in the terminal window.
  • theopaone
    theopaone over 13 years ago
    If you want the script to communicate with SKILL, you should look at the IPC functions such as ipcBeginProcess. Otherwise, the script is executed in a separate shell with no connection back to Virtuoso.
     Ted
  • imagesensor123
    Hello Andrew,
        my script ("myCheck.sh") is as following:
         #! /usr/local/bin/tcsh
         ic5141
         ams370
         spectre input2T5.scs
         grep Vout -w capFile > capOut
    the script is firstly to lunch the simulation and then process the file "capFile" to extract some info into file "capOut". in fact, when i use the command csh("myCheck.sh"), it just return "t" in CIW, no result is generated!
    you mentioned the results(any output) will appear in the terminal, but I never see any terminal is trigered and turned up in this whole procedure!
    regards,
    zfeng
  • imagesensor123
    Hello thepaone, thx, yes, you're right! my idea is to start the simulation in backgroud to extract some low level parameter to be used later in high level modeling!
    Does the script work if you run it from the terminal? Have you made it executable?
  • imagesensor123
    Hello, yes, I can start and run it in terminal perfectly, it works like what i expect! I just have some trouble in skill procedure (CIW), no it's just a common script file!
  • imagesensor123
        question is cleared!
        the right solution is: 1, make the script to be a exacutable *.sh firstly.
                                      2, cd to current directory
                                      3, csh("./*.sh")
    regards,
    zfeng
