  3. A question about parameter in skill.
  • Views 19284
layes
layes over 13 years ago
I have a question about parameter in skill.
When I using Csh I can use $1 $2 as input parameter in script.
How can I pass it to skill,if I include some skill script in my Csh script?
thanks.
  • theopaone
    theopaone over 13 years ago
    You cannot directly evaluate a SKILL function in the shell. Put the SKILL function name and its call into a file you pass to Virtuoso. You have to start Virtuoso and use the -replay argument. The function should also execute exit() to close the Virtuoso session:
    echo "load( \"mySkillFunction.il\" ) mySkillFunction( $1 $2 ) exit()" > runMySkillFunc.il
    virtuoso -nograph -replay runMySkillFunc.il
    Ted
  • layes
    let me explain my question in detail:
    I have a script "ab.csh"
    #!/bin/csh
    ls $1>celllist
    icfb -nograph -replay ab.il
    I have a skill script "ab.il"
    procedure(ab(lib1 lib2)
    ab("$1" "$2")
    exit()
    I run in c_shell commands as below:
    ab.csh analib diglib
    It seems that this does not work,could you help me about this ,thanks.
  • theopaone
     $1 and $2 do not have values inside icfb. You have to create a new SKILL function with the values from $1 and $2 in the function call. That is why I included the echo statement above, the $1 and $2 values are put into the function runMySkillFunc.il and when it is loaded the function is executed with the values.
    In addition, the replay file does not automatically load the file ab.il. That is why I had the load statement in my echo output above.
    For your problem you need to create a file, we will call it runab.il. It should contain the following statements which could all be on the same line:
    load("ab.il")
    ab( "analib" "diglib" )
    exit()
    ; Ted
    The other thing you could do is to set an environment variable containing the arguments inside your script:
    #!/bin/sh
    export ARGS="$0 $*"
    icfb -nograph -restore ab.il
    And then in the SKILL code (ab.il)
    args=listToVector(parseString(getShellEnvVar("ARGS")||""))
    printf("The script was called %s\n" args[0])
    printf("The arguments were '%s' and '%s'\n" args[1] args[2])
    exit()
    If I then do "runScript hello world" I get:
    The script was called runScript
    The arguments were 'hello' and 'world'
