  3. How to access parameters of an instance?
  • Subscribers 150
  • Views 23892
mvijay
mvijay over 13 years ago
I want to access the parameters of an instance in a layout and then compare it with conditions to print and output. Following is the code I am trying:
cv =geGetEditCellView()
cv~>instances
instanceParam=cv~>instances~>parameters~>??
The last line of code gives result as nil in CIW.
Would like help regarding the same.
Vijay
  • Quek
    Quek over 13 years ago
    Hi Vijay
    Perhaps you can use this:
    procedure( printParams()
       let( (inst cdf)
          inst=car(geGetSelSet())
          cdf=cdfGetBaseCellCDF(ddGetObj(inst~>libName inst~>cellName))
          foreach( param cdf->parameters
             printf("Value of %s: %L\n" param~>name get(inst param~>name))
          ) ;foreach
          printf("Job done\n")
       ) ;let
    ) ;procedure
    hiSetBindKey("Layout" "F10" "printParams()")
    Best regards
    Quek
    I'd also probably do either this:
    foreach(mapcar prop inst~>props list(prop~>name prop~>value))
    this won't tell you any properties not actually on the instance, i.e. those at CDF defaults.
    The alternative would be to do:
    cdf=cdfGetInstCDF(inst)
    foreach(mapcar param inst~>parameters list(param~>name param~>value))
    Which effectively does the same as Quek's except I'd change it to:
       let( (inst cdf)
             printf("Value of %s: %L\n" param~>name param~>value)
          ) ;foreach
       ) ;let
    ) ;procedure
  • theopaone
    theopaone over 13 years ago
     If you are looking for the parameter values assigned to an instance of a pcell, you should get those values off the master. There may be some parameters not assigned through the CDF or some CDF parameters that are not pcell parameters.
    inst~>master~>parameters gets the parameters off the master, including those that are the CDF default.
    Ted
  • mvijay
    Thanks for the response. I have a doubt however, as I was trying the code:
    cdf=cdfGetInstCDF(inst) , yields "nil" in CIW.
    inst=car(gegetSelSet()) would throw the database ID as db:0x.......
    cdfGetInstCDF whereas needs d_instID to work upon.
    What I am trying to do is to access the "Parameter" tab of an instance placed in a cellview (layout) and trying to make comparision with condtions thereafter.
  • mvijay
    I figured out the code above works all right for a proper CDF component viz. transistors.
    In a tech library, the VIAS are not defined as CDF. I could figure it out from the cdf of it. I was wondering, what they would be, object wise.
    Can I access the parameters of any object which are not necessarily cdfs?
    Vijay
    obj~>prop~>name and obj~>prop~>value if it's a database object  you're talking about.
