  3. Edit in place correct dbCreate* adjustments
  • Views 13440
psill00
psill00 over 12 years ago
Is there a equivalent enter box and path to  geWindowToEditPoint?
And is there a way to get the correct oreintation to use dbCreate* functions?
    If you mean you have a list of points, or a box (as returned by enterPoints() or enterBox() respectively), then you could transform them using:
    win=hiGetCurrentWindow()
    editBox=foreach(mapcar point box geWindowToEditPoint(win point))
    You'd use exactly the same code passing in points instead of box if it was a list of points in the window coordinate system.
    You may also find this post useful for orientation details etc.
    Kind Regards,
